Author Topic: Seeking a Quickfire Rapid Ctrl keycap?  (Read 3949 times)
Offline Prisoner416
« on: Mon, 24 February 2020, 19:31:13 »
This is a bit of a longshot, but I have OCD and if anyone has a ctrl key from a CMStorm Quickfire Rapid, I'd be grateful. All the other keys I have are fine, and I really don't want to have to buy an entire used keyboard to satisy my OCD. Picture for reference.
Offline Hyde
  • White Tofu Extraordinaire
Re: Seeking a Quickfire Rapid Ctrl keycap?
« Reply #1 on: Mon, 24 February 2020, 21:10:28 »
It's gonna be hard since it's been discontinued for so long, also even if people have it chances are they won't want to sell you just 1 of their keys.
I think the closest would be this:
https://www.wasdkeyboards.com/custom-art-cherry-mx-keycaps.html
Where you can upload your own graphic to match the existing font.  Though this require Adobe Illustrator skills.
It almost feels it might actually easier for you to just buy an entire new set unfortunately.
Offline Prisoner416
« Reply #2 on: Mon, 24 February 2020, 21:13:58 »
Figured there might be a slim chance that someone here bought one and replaced the keys with customs and/or no longer uses it.
Offline wiredPANDA
« Reply #3 on: Fri, 06 March 2020, 17:43:38 »
So I'm that random guy. I have an old Rapidfire that I replaced caps on years ago. Haven't been active on GH or other forums in a minute, but I'll go check storage to see if I still have the OEM keys saved.
PM me
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
