Author Topic: Help with keyboard selection for Dad  (Read 1807 times)
Offline sanctions23
« on: Fri, 28 February 2020, 02:44:10 »
My Dad has been using a Razer Blackwidow Tournament X keyboard (https://www.razer.com/gaming-keyboards-keypads/razer-blackwidow-x-tournament-edition-chroma) for the past few years, and has really liked it.  A couple days ago he spilt coffee on it and bricked it.  He would like something of similar chassis design, with full back-lighting, and similar keys (so basically Cherry MX Blue).
I haven't had great luck finding something similar, and so am asking for help.  Thanks all in advance for your suggestions.
Re: Help with keyboard selection for Dad
« Reply #1 on: Fri, 28 February 2020, 03:30:59 »
When RGB is required you can't go far wrong with a Ducky and this one comes with blues (that's not a recommendation for the seller just the first place I found it, not in stock anyway)  It has small bezels and a shallow wedge shape so hopefully that's a similar chassis?
Offline DarwinH
« Reply #2 on: Fri, 28 February 2020, 03:44:51 »
This Corsair I think matches what you're looking for - https://popular.reviews/wireless-mechanical-keyboard/#1_CORSAIR_K63_CH-9145030-NA
Design-wise it should be pretty up to par for older folks who need a user-friendly keyboard to work with, something simplistic that doesn't go over their heads.
