Author Topic: Model F (XT) to USB?  (Read 5626 times)
Offline EverythingIBM
« on: Mon, 21 June 2010, 23:30:42 »
I thought of a funny idea.
Alright, for a model F XT keyboard if you stick on an AT to PS/2, then, stick on a PS/2 to USB -- if the USB converter could do something with the XT signal?
I don't have a PS/2 to USB converter (although I should look into a blue cube some time in the future), so, I can't test this out. Anyone else willing to give it a try?
Because there are so many different PS/2 to USB converters, I'm wondering if an XT signal could be "converted" by any of them -- if there's a chance of it being possible.
Offline maxlugar
« Reply #1 on: Tue, 22 June 2010, 01:54:00 »
Quote from: EverythingIBM;195376
Maybe you'll get lucky and find a blue cube USB converter in the rubbish bin tomorrow.  Then you could put your brilliant hypothesis to the test!
Emperor of the IBM 84-key AT Model F Darkside
Offline trievalot
« Reply #2 on: Tue, 22 June 2010, 05:22:20 »
hang on.....ill try
BRB
[SIGPIC]
Offline ch_123
« Reply #3 on: Tue, 22 June 2010, 05:25:30 »
Ah come on, don't spoil the fun!
Offline trievalot
« Reply #4 on: Tue, 22 June 2010, 05:28:57 »
nope.....nothing
AT F works
XF F - not even a keystroke
[SIGPIC]
Offline ch_123
« Reply #5 on: Tue, 22 June 2010, 05:31:53 »
Who ever could have foreseen that a PS/2 to USB adapter could not work with a PS/2 incompatible keyboard?
Offline trievalot
« Reply #6 on: Tue, 22 June 2010, 05:32:22 »
HANG ON
It just started working, and it has a windows key, and caps/scroll lights, and an awesome trackball!!!!
[SIGPIC]
Offline ch_123
« Reply #7 on: Tue, 22 June 2010, 05:36:06 »
Offline trievalot
« Reply #8 on: Tue, 22 June 2010, 05:39:31 »
bit more like this actually.......as IF it would change colour.....thats just silly
[SIGPIC]
Offline ch_123
« Reply #9 on: Tue, 22 June 2010, 05:48:21 »
The logo changed from aluminium to plastic!
Offline Half-Saint
« Reply #10 on: Tue, 22 June 2010, 06:33:44 »
I'm sorry but this has to be the worst idea of all times!
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline kriminal
« Reply #11 on: Tue, 22 June 2010, 09:27:33 »
haha
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline ch_123
« Reply #12 on: Tue, 22 June 2010, 14:50:17 »
Quote from: ripster;195458
The OP has had many worse.
At least this time he didn't give it as advice to noobies.
Maybe it works with the IBM PC300?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #13 on: Tue, 22 June 2010, 15:47:37 »
I literally just facepalmed.
Cheers Geekhack.
kishy.ca
Offline ricercar
  • mostly abides
« Reply #14 on: Wed, 23 June 2010, 13:23:03 »
Quote from: ripster;195390
Let me guess.  You're an English Major.
Hey, I was an English major and even I don't understand the OP. I know what he's trying to do, but the post isn't telling me how.
Offline dfj
  • Visit our irc: #geekhack on libera.chat!
Not as improbable as rip might have us think...
« Reply #15 on: Thu, 24 June 2010, 01:09:08 »
  Feeding ze troll:
 I think the easiest way to connect to a PC is via something similar to sethstorm's  driver replacement trick for 122s.
  As far as USB goes, yer going to have to wait a bit for our open source drivers to mature then build yerself an adapter. The protocol on the F is different than the one on the PS2, so none of the (cheap or otherwise) PS2->USB adapters will work.
  If I remember:  the XT uses 'scancode page 1' as the protocol, while PS2 keyboards use page 2, and the IBM 122 key keyboards (both F and M) use page 3. Electrically, they are all very similar, though - and the same low-level code can be used to handle the bunch of them - provided it is wise enough to not freak out about a few timing differences.
  Quite frankly, page 1 and three are both sane, while it is 2 that is bizarre, but the world went with 2, sadly. I am not aware of any commercially  available ps2 to USB adapters that support page 1 or 3, currently.
  We are working on one here (myself, seth, mnemonix, and (what happened to thedward?) and grrr someone else - I'll edit shortly once I find the posts ).
  Anyway, now that I have some 122 F's to play with I'll be making _some_ progress very shortly, at least.
dfj
Fave Switch manus: IBM, Topre, Matias, ...
