Author Topic: [IC] GMK Rouge - *GB THREAD UP*  (Read 139779 times)
Offline Emir
  • icon mods
  • Bandit
    • Discord
Re: [IC] GMK Rouge - *PRICING REVEALED* LIVE IN JUNE!
« Reply #150 on: Sun, 24 May 2020, 09:37:02 »
Pricing is here:
Unfortunately it is a bit more expensive than Firefly, even though the amount of keys are less (base). The reasoning for this is the amount of colors. GMK has a minimum order quantity for colors, and buying out MOQ for colors to use just on 1 key x4 raised the quote.
I think it is OK all things considered! :)
Make sure to join my discord server for discussion and news too:
https://discord.gg/MwVTg2E
Given the couple unique qualities of the set, those prices strike me as fair. I wouldn't say no to a lower price, but it seems reasonable as-is. Nice!
Yes it is what it is. :/ I would've loved for a better price too. If it was a slower month we might've tried to base the pricing on the 500 MoQ, but the way June is looking now unfortunately we got to settle for 250 MoQ.
Thank you for the support!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #151 on: Mon, 25 May 2020, 12:55:55 »
Deskhero has been added as a vendor!
Live june 1st through june 30!
Offline cohesive_glue
« Reply #152 on: Mon, 25 May 2020, 16:09:04 »
Love the color!
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #153 on: Mon, 25 May 2020, 16:46:35 »
no deskmats for this wonderful set?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #154 on: Mon, 25 May 2020, 16:52:55 »
What a great purple set! Will pick up a key set once it goes live. Good idea with the gradient!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #155 on: Tue, 26 May 2020, 05:18:29 »
No plans for it, sorry!
Love the color!
Thank you so much!!
Offline kaisn
« Reply #156 on: Tue, 26 May 2020, 05:44:41 »
I really appreciate the mods. Cant wait
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #157 on: Wed, 27 May 2020, 10:59:31 »
Everyone should appreciate OG icon mods, the best mods. :D
Offline hkhawk
« Reply #158 on: Wed, 27 May 2020, 12:50:14 »
I'm a big fan of the colors. Emir, where are you in the color matching process on this? Have you picked out the RALs? If so, can you share with us? Just curious because I see that color matching on Firefly is still ongoing and I'm super interested in jumping on this GB. Any info you could share about how you think the color matching process will go and what the next steps will be now and after GB would be very helpful for me purchase decision.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #159 on: Wed, 27 May 2020, 18:02:00 »
Base - RAL 280 30 15
Legends - 320 50 20
1 - 310 20 20
2 - 310 30 20
3 - 300 30 20
4 - 300 30 15
Color matching will start after the order is placed or slightly before. It can be done prior to gb, but at a cost.
Offline hkhawk
« Reply #160 on: Wed, 27 May 2020, 21:59:36 »
Legends - 320 50 20
1 - 310 20 20
2 - 310 30 20
3 - 300 30 20
4 - 300 30 15
Awesome, thank you so much!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #161 on: Thu, 28 May 2020, 09:54:26 »
Legends - 320 50 20
1 - 310 20 20
2 - 310 30 20
3 - 300 30 20
4 - 300 30 15
Correction, base RAL is 290 20 15, my fingers slipped on the first values for the two first combinations!
Offline euphxenos
« Reply #162 on: Thu, 28 May 2020, 15:45:29 »
Do you have samples in hand to verify that those RAL colors really are what you want this time around?
https://geekhack.org/index.php?topic=102667.msg2858497#msg2858497
"The next set I launch will have cleared color samples before I even post an IC."
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #163 on: Thu, 28 May 2020, 16:25:07 »
Yes
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #164 on: Sun, 31 May 2020, 07:31:57 »
GB Thread posted, live tomorrow! Hype  :eek:
Offline Emir
  • icon mods
  • Bandit
    • Discord
Re: [IC] GMK Rouge - *GB THREAD UP*
« Reply #165 on: Sun, 31 May 2020, 14:25:13 »
