Author Topic: Dirt cheap ceramic knives  (Read 4769 times)
Offline Infinite north
« on: Tue, 22 June 2010, 15:54:47 »
I cook for a living and have an obsession with kitchen knives. one type of knife that I have never really had any interest in are ceramic knives. While they are very sharp they are so easy to damage. When kitchens get busy your gear needs to be able to take some abuse. I have worked with a few people who had their expensive ceramics break. the high cost of them used to be a drawback also, I remember that not too many years ago they could cost hundreds of dollars for a single knife because of limited production. the edge on the blade can make it hard to cut waxy skinned items as well.
I found some at harbor freight tools the other day and they are just too cheap to pass up. while the sharpness might not compare to a kyocera, it's more than acceptable for cooking at home.
http://www.harborfreight.com/catalogsearch/result/?category=&q=ceramic+knife
Offline didjamatic
« Reply #1 on: Tue, 22 June 2010, 15:58:09 »
Very cool!  Have you used them yet? I've wanted some ceramics but the price is a killer.  I looked at the Kyos but bought my wife a block of Messermeister knives.  They are incredible, but require sharpening periodically.
« Reply #2 on: Tue, 22 June 2010, 16:39:53 »
Yeah I picked up the paring knife because it was the cheapest, just to get a feel for it. without testing it side by side it seems comparably sharp to any I have used in the past. I don't know how durable it is comparatively but the chemical components should be pretty similar as there is only one way to make these knives. I plan on grabbing some more for a friend.
If anyone is going to get some of these I would suggest that they skip the 5in utility. the paring and the chefs are pretty much all you would need. some people don't like to use chefs knives though so I suppose that it comes down to personal taste.
Offline Rajagra
« Reply #3 on: Tue, 22 June 2010, 17:14:32 »
Somebody made a straight razor from a ceramic blade. Conclusions:
"Ceramic is not that fun to hone"
And later:
"I decided to not waste my time with it anymore"
A sad end to a project that had raised people's hopes. A bit like the shaving equivalent of the Miniguru.
200X closeup of edge:
Offline EverythingIBM
« Reply #4 on: Tue, 22 June 2010, 18:06:26 »
I just use plain old stainless steel knives. But then again, I don't chop up things every day, and I mostly enjoy making pasta -- my model M loves pasta too it seems.
Offline elbowglue
« Reply #5 on: Tue, 22 June 2010, 18:32:37 »
Hm I am interested in trying out a ceramic blade too...  What do you think about this one to try: http://www.amazon.com/eMark-Delux-3inch-Ceramic-Paring/dp/B003A8RPM0/ref=sr_1_15?ie=UTF8&s=home-garden&qid=1277249450&sr=8-15  It would be free shipping for me..
Do you guys think that cheap ceramic blades work as well as pricey ones in general?
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline chimera15
« Reply #6 on: Tue, 22 June 2010, 18:56:53 »
I've had ceramic pocket knives for like a decade.  Once the manufacturer edge is worn, it becomes very very difficult, even with diamond sharpening whetstones to put another good really sharp edge back on the blade.  You have to send it back to the factory basically.   It's a major pain.
Also they're useless to pry or do anything that requires torque like you can with a metal blade.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Rajagra
« Reply #7 on: Wed, 23 June 2010, 00:20:35 »
Is that yellow sticker a warning that the knife may have sharp edges? Say it isn't so. Even by U.S. standards that would be lame.
« Reply #8 on: Wed, 23 June 2010, 01:18:32 »
I like that you wouldn't get him one but you needed one yourself.
Quote from: elbowglue;195576
I am sure you do get what you pay for in a way. the only thing is you probably won't dull the knife any time soon unless you neglect it. butchers typically have their knives professionally sharpened every other week at the latest. good sushi chefs hone their knives every day. most people don't know how to maintain a knife edge so ceramics are great because the edge is retained with little care.
I doubt you would benefit from spending more money on a very similar knife. spending more money without rigorously using the knife is kind of pointless. the quality you would get would be unnoticeable for the most part.
