Author Topic: Looking for 60% PCB..  (Read 2120 times)
Offline shadowku
« on: Tue, 10 March 2020, 09:33:12 »
I'm looking for a 60% PCB that can do Tsangan layout with an arrow cluster all on the bottom-right row (so 4 1U keys).
I would greatly prefer RGB per key.
QMK would be nice.
Does not need hot-swap.
KBD's DZ60 REV 3.0 could work but it doesn't have RGB. Otherwise it fits.
I'm not too familiar with what's out there since I've been using mainly Topre.
Any other suggestions?
HHKB Pro2      FC660C
Offline rinkaan
Re: Looking for 60% PCB..
« Reply #1 on: Tue, 10 March 2020, 20:20:37 »
GK64?
https://m.tb.cn/h.Ven0n8p?sm=32da0a
per key RGB, arrow cluster, type c, hotswappable
Sent from my Redmi K20 Pro using Tapatalk
Offline rinkaan
« Reply #2 on: Tue, 10 March 2020, 20:22:17 »
Sample Pic of the layout once built.
Offline shadowku
« Reply #3 on: Tue, 10 March 2020, 21:14:22 »
GK64?
Thanks
I've considered the GK64 but I'm worried about the 2U Left shift for keycaps.. or does the GK64 not always have the 2U Shift?
HHKB Pro2      FC660C
Offline rinkaan
« Reply #4 on: Wed, 11 March 2020, 00:14:30 »
Yeah that is the more uncommon size... But generally Chinese large keycap sets will include them. Most premium sets floating about here usually have them as well. Which keycap are u interested in...
If u want shine thru doubleshot abs... There aren't too many cheap options in China...
Offline rinkaan
« Reply #5 on: Wed, 11 March 2020, 00:20:22 »
but for a full size set, u can use the numpad keys (+, enter, 0) which are 2 U.
Offline rinkaan
« Reply #6 on: Wed, 11 March 2020, 00:21:42 »
Some taihao double shot abs shine thru keycaps
https://m.tb.cn/h.VVIUTPV?sm=f04b45
