Author Topic: Help identify the old keyboard!  (Read 2244 times)
Offline Mikhail
« on: Tue, 10 March 2020, 09:43:23 »
Top one. The seller says that the keeb are in perfect condition.
Thank you!
Offline Tactile
Re: Help identify the old keyboard!
« Reply #1 on: Tue, 10 March 2020, 14:17:30 »
The top one looks like a keyboard for a DEC VT320 terminal.
237589-0
REΛLFORCE
« Reply #2 on: Tue, 10 March 2020, 14:26:07 »
It's a clone of the DEC LK201 for sure. That does not mean it is compatible with the DEC terminal though — it might just copy the layout.
But clones with the F-key overlay in front of the F-keys (or is it LED decal?), and a normal-sized Return key are unusual.
« Last Edit: Tue, 10 March 2020, 14:29:04 by Findecanor »
Offline Mikhail
« Reply #3 on: Tue, 10 March 2020, 16:13:26 »
Thank you for info! I think that as it's clone, they used a standard keycaps, thats why Return key is normal-sized))
