Author Topic: What ahk scripts do you use?  (Read 2956 times)
Offline Infinite north
« on: Wed, 23 June 2010, 17:09:10 »
I personally haven't used ahk much because the learning curve. I am wondering what scripts forum members use on a daily basis. uploading files would be great too.
Offline Rajagra
« Reply #1 on: Wed, 23 June 2010, 17:24:45 »
I use a script to give me easy access to navigation keys etc.
AHK is tricky to get in to, but you can just browse the help file for what you need and copy ideas from other scripts. Some kind of formal description of the language would be nice though.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Wed, 23 June 2010, 17:55:44 »
I like the concept of having arrow keys on both hands.
Offline nanu
    • http://T-T.be/portal
« Reply #3 on: Wed, 23 June 2010, 18:44:21 »
Some of my AHK scripts (includes some of which I never use, or have quit using)
Offline chimera15
« Reply #4 on: Fri, 25 June 2010, 03:51:45 »
I made a script to use with a nostromo for playing poker, so I could play multiple tables easier, and so I didn't have to use my mouse to bet and junk, and so my timing tells wouldn't be so obvious.  Wasn't that hard.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline DreymaR
  • Colemak forum guy
    • DreymaR's Big Bag of Kbd Tricks
« Reply #5 on: Fri, 25 June 2010, 07:54:34 »
PortableKeyboardLayout - hard to beat.
Better burden you cannot carry than man-wisdom much ~ Hávamál
Offline kidchunks
« Reply #6 on: Sat, 27 November 2010, 12:08:51 »
Neat, I've been wanting to give ahk a try out since getting my filco. Thx for the sample scripts!
Topre || BS > *
my root : kidchunks[dot]com
Offline JBert
« Reply #7 on: Mon, 29 November 2010, 16:07:53 »
Quote from: ripster;253006
Finally figured this one out.  Put Autohotkey.exe in the startup folder and your Ahk script in the documents folder.  Then make sure Autohotkey.exe is NOT elevated to admin privileges.   Also do not check compatibility mode. You have to confirm it once but after that you don't get the nag message at boot anymore.
I copied the .ahk script into my StartUp folder and it boots just fine.
The only issue is that it won't work for elevated screens seeing how the AHK process isn't.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #8 on: Mon, 29 November 2010, 16:24:19 »
I used to use AHK Poker scripts for pokerstars and full tilt poker.  I was able to utilize MIDI controllers, game controllers, and the keyboard to automate bet sizes.
I <3 BS
Offline CeeSA
« Reply #9 on: Mon, 06 December 2010, 08:43:22 »
perhaps someone know the solution.
i want a funktion key press, release and have the funktion for the next button press
the way i would like:
press the window key
release the window key
press F1 (inside 2 sec. or something else) for mute (example above)
normal way:
hold the window key
press F1 (in  addition) for mute
Offline CeeSA
« Reply #10 on: Mon, 06 December 2010, 10:02:08 »
there is nothing wrong...
would only nice to know the solution for guys without thumbs
