Author Topic: Canoe Plate  (Read 3295 times)
Offline synmuffin
Canoe Plate
« on: Thu, 12 March 2020, 15:18:30 »
I would like to get my own copper plate cut for a Canoe keyboard I have, does someone have a cad of a plate for this, or is there somewhere I can get one cut who already has the design?
Thanks.
Offline DNLTLM
Re: Canoe Plate
« Reply #1 on: Thu, 12 March 2020, 15:29:48 »
http://builder-docs.swillkb.com/
can help you to make SVG of plate, and if you need 3d sample you can do this in fusion 360.
Offline synmuffin
Re: Canoe Plate
« Reply #2 on: Fri, 13 March 2020, 11:10:07 »
Thanks I've been tying to use this thing for a while, but it seems to have an issue when I want to cut away specific parts of the switch layer, has anyone else got this to work?
Offline DNLTLM
Re: Canoe Plate
« Reply #3 on: Fri, 13 March 2020, 11:55:40 »
Sorry I'm can't understand, your issue in Fusion 360? Or in plate generator? You want to change your plate in Fusion?
Offline synmuffin
Re: Canoe Plate
« Reply #4 on: Fri, 13 March 2020, 12:06:53 »
My issue is with the plate generator, I am unable to get it to cut away parts of the switch layer that I need it to, it simply doesn't show up on the CAD, however if I tell it to "Add" instead of "Cut" it shows up, and right where I would like it to, so I know it's in the right place, it simply won't allow me to "Cut" for some reason. However it looks like I'm not the only one having this issue: https://www.reddit.com/r/MechanicalKeyboards/comments/fcclr2/swillkb_plate_generator_help_cut_polygon_is_not/
Offline DNLTLM
Re: Canoe Plate
« Reply #5 on: Fri, 13 March 2020, 12:24:52 »
Ok, i don't know the solution because i work with plate in fusion, you can try change svg in inkscape.
