Author Topic: Adesso MKB125B  (Read 5572 times)
Offline ecru
Adesso MKB125B
« on: Thu, 24 June 2010, 03:43:14 »
Today I received an Adesso MKB125B, ordered from CompSource through a buying service (International Checkout).
Build quality isn't as good as Cherry, Raptor-Gaming or Filco boards I have seen, however the MKB125B is much cheaper.
Adesso advertises it as "It features an n-key rollover function permitting up to 10 keys to be pressed at the same time."  This is false.  It is 2 key rollover on both usb and the provided usb to ps2 adaptor.  Due to freight costs (apart from the hassle), it isn't worth returning the board.  Note from the photos that there is no diode on each switch.
The keys have a slightly rough finish.  The font is excessively large compared to other boards.  The 'F' and 'J' key have a rectangular nipple.  I quite like the matt finish on the casing which is a little smoother than the keys.  The spots between the number line and the function line in the first photo are from casting, however aren't noticeable in normal usage.  The green leds are a little dim, but still fine.
It is still early, but I think the blues could become my preferred Cherry switch.  I think Model M buckling springs will remain my 'ideal'.  After evaluating Cherry Blacks in a Raptor-Gaming K1 (which arrived today too), I may swap the Cherry Blue sliders and springs into that board.  The Cherry Blacks aren't as bad as I was expecting, but I doubt I will prefer them over other Cherry types.
edit - first photo disappeared for some reason
« Last Edit: Tue, 29 June 2010, 02:31:06 by ecru »
Offline aegrotatio
Adesso MKB125B
« Reply #1 on: Thu, 24 June 2010, 15:21:32 »
Wow, the N-key rollover doesn't work?  This is very bad because this keyboard is specifically intended for gamers, even more so than the larger MKB-135B which internally looks not the same as this one.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Adesso MKB125B
« Reply #2 on: Wed, 30 June 2010, 06:46:21 »
Hmm, the controller PCB says "SC-M10"... maybe this one is based on the Scorpius M10 internally?
The base PCB material is pretty cheap stuff btw.
Offline aegrotatio
Adesso MKB125B
« Reply #3 on: Wed, 30 June 2010, 14:54:44 »
But, then, the Adesso MKB-125B looks nothing like the Adesso MKB-135B internally.  I can't see any similarity; even the main PCB looks different.
Offline ricercar
  • mostly abides
Adesso MKB125B
« Reply #4 on: Wed, 30 June 2010, 15:59:04 »
Quote from: keyb_gr;197883
The Adesso and Scorpius M10 don't share a PCB. I don't recall the thread, but it was probably the one ripster mentioned. The pics of the Adesso PCB were clearly different than my Scorpius PCB.
Offline Nonmouse
Adesso MKB125B
« Reply #5 on: Thu, 01 July 2010, 12:39:30 »
Quote from: aegrotatio;195983
If you look at the bottom shot of the PCB, it's clear that it uses non-diode MX switches (only two pins) and there are no external diodes.  Kinda hard to get NKRO without diodes...
Offline aegrotatio
Adesso MKB125B
« Reply #6 on: Thu, 01 July 2010, 13:00:07 »
I agree with 50 cents for diodes, but what of the labor cost, or does their automatic tooling support diode insertion of diodes (if they are not hand-assembled)?
Both are not 50 cents, just saying.
Offline aegrotatio
Adesso MKB125B
« Reply #7 on: Thu, 01 July 2010, 13:17:56 »
Yeah I saw Cherry boards with the diodes in the little slot and some are mounted on the PCB.  I bet it's a wash which one is more expensive but I thought there is more to NKRO/anti-ghosting than just diodes.
Offline aegrotatio
Adesso MKB125B
« Reply #8 on: Thu, 01 July 2010, 13:30:52 »
Sucks...
Then I'm someone who plays Half Life 2 on a 20-year-old Model M keyboard and still wonders what the fuss is about.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Adesso MKB125B
« Reply #9 on: Thu, 01 July 2010, 14:01:00 »
Quote from: aegrotatio;198338
Sucks...
Half Life + Model M is an excellent combination. Although blocking issues exist if you look for them, I never actually found such an issue myself.
Do you have Opposing Force and Blue Shift as well?
kishy.ca
Offline EverythingIBM
Adesso MKB125B
« Reply #10 on: Thu, 01 July 2010, 14:10:42 »
Quote from: kishy;198352
I play all my games on my model M as well, I've come across no problems. I mostly just use the arrow keys lol... modern games don't really demand much.
But some DOS games can get really complicated and require many keys. As if anyone in this age plays them -- let alone have the capacity to understand them.
Offline aegrotatio
Adesso MKB125B
« Reply #11 on: Thu, 01 July 2010, 14:55:15 »
I have the non-source Opposing Force but never installed it, I think it came with Game of the Year edition.
Sometimes I use WASD but if the keyboard has a numeric keypad I always use that one.
Offline ghost128
Adesso MKB125B
« Reply #12 on: Tue, 24 April 2012, 20:02:11 »
I know this is a necropost, but I just recieved a copy of this key board and NKRO works fine.
