Author Topic: Please identify  (Read 4277 times)
Offline trievalot
Please identify
« on: Thu, 24 June 2010, 07:26:19 »
is it ALPS? and is it worth $50 in this condition?
[SIGPIC]
Offline ch_123
Please identify
« Reply #1 on: Thu, 24 June 2010, 07:29:26 »
It looks like one of those calculator boards without the LCD screen...
Offline trievalot
Please identify
« Reply #2 on: Thu, 24 June 2010, 07:36:28 »
i think its a cheese sandwitch
[SIGPIC]
Offline chimera15
Please identify
« Reply #3 on: Thu, 24 June 2010, 07:40:22 »
Very good chance it is, but there were also rubber domes made like this.  I have a focus board that is rubber dome, and not alps.
I think the middle key section gives it away though as likely being a focus/northgate clone.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline trievalot
Please identify
« Reply #4 on: Thu, 24 June 2010, 07:50:45 »
if its an FK-9000 then it SHOULD be, rite?
[SIGPIC]
Offline didjamatic
Please identify
« Reply #5 on: Thu, 24 June 2010, 08:28:26 »
Yep.  Nice keyboard, $50 is a good price.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Please identify
« Reply #6 on: Thu, 24 June 2010, 14:58:32 »
That looks remarkably like an FK-5001. Screen looks like it's there CH, just lighting is bad.
Differences...note LEDs are in the keys, and it doesn't look like the logo plate is removable (for DIP switches underneath). Also key layout above calculator looks a bit off because KB Lock and Calc Lock are one combined toggle key on this one.
(because the KB/Calc lock key is present, it definitely has a calculator)
Key profile looks a bit funny...might be Alps, might not.
« Last Edit: Thu, 24 June 2010, 15:01:02 by kishy »
kishy.ca
Offline trievalot
Please identify
« Reply #7 on: Thu, 24 June 2010, 19:07:09 »
How can they TELL if its a ALPS?
is there an easy way? (just click the key?)
[SIGPIC]
Offline ch_123
Please identify
« Reply #8 on: Thu, 24 June 2010, 19:09:36 »
Pop a keycap.
See if it clicks? Well, that would limit it to... about a dozen switch types?
Offline didjamatic
Please identify
« Reply #9 on: Thu, 24 June 2010, 19:42:19 »
Based on it's vintage, the unikey arrow cluster, make, model and the link I posted above... it has ALPS.
But then again, I just opened a Qtronix board I got in the mail that I was certain had Cherry Blues in it and BAM! rubber dome.  Straight into the recycle bin.
Offline ch_123
Please identify
« Reply #10 on: Thu, 24 June 2010, 19:44:12 »
It could have Alps-like switches. If this was the case, this could make the keyboard more, or much less desirable than an Alps keyboard.
Offline trievalot
Please identify
« Reply #11 on: Fri, 25 June 2010, 06:17:35 »
well, definately a FK-9000,
ordered, and apparently in original box!
[SIGPIC]
Offline EverythingIBM
Please identify
« Reply #12 on: Fri, 25 June 2010, 13:55:42 »
Quote from: trievalot;196212
Don't those things need some type of discontinued battery to be able to turn on?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Please identify
« Reply #13 on: Fri, 25 June 2010, 17:23:28 »
CR-2032 if it's like a 5001. 3 for a buck all over the place.
kishy.ca
Offline spolia optima
Please identify
« Reply #14 on: Fri, 25 June 2010, 17:40:59 »
Quote from: EverythingIBM;196354
It should work without battery when plugged in.
keyboards!
Offline trievalot
Please identify
« Reply #15 on: Fri, 25 June 2010, 17:57:08 »
will the calculator work powered off the USB to PS2 to AT convertor?
(if i dont add in another battery i mean)
[SIGPIC]
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Please identify
« Reply #16 on: Fri, 25 June 2010, 19:44:33 »
I'd recommend reading my review of that very same keyboard here.
