Author Topic: Best 65% Case Under $200 w/ RGB Underglow (Or White Glow Only)  (Read 3073 times)
Offline BlindFaith
Hey Everyone,
I am looking for a 65% case with RGB or white underglow so maybe some sort of diffuser like on the https://kbdfans.com/collections/diy-kit/products/kbd75v2-custom-keyboard-diy-kit. It is really hard to catch the group buys before they are over but maybe I am looking in the wrong place or something. Not sure if anyone has any good reccomendations.
Cheers,
Offline Sup
Re: Best 65% Case Under $200 w/ RGB Underglow (Or White Glow Only)
« Reply #1 on: Fri, 20 March 2020, 12:30:53 »
There is none that you can just go out and buy from my knowledge with a RGB diffuser.
current
Coming soon
Offline BlindFaith
« Reply #2 on: Fri, 20 March 2020, 14:28:49 »
That is too bad maybe I need to give up my controllable underlighting dreams and go for something more classic. Hmmmmmm things to think about.
Offline typo
« Reply #3 on: Sat, 21 March 2020, 11:34:48 »
My bad, I was thinking OP meant something else. Sorry. Can't help you. You need custom built. You should wait up to 1-1/2 years to get it. Or forget the under glow.
« Last Edit: Sat, 21 March 2020, 11:41:16 by typo »
Offline typo
« Reply #4 on: Sun, 22 March 2020, 09:28:27 »
Hey, I just thought of one! Drop Alt! It has everything you want. Bare bones very close to your budget on Amazon. You will need key caps, switches ETC. I was not sure if your budget was for the case or complete. I would recommend the "high" model.
Offline rxc92
« Reply #5 on: Sun, 22 March 2020, 09:52:34 »
Hey Everyone,
Cheers,
Normally KBDfans sell these boards on taobao. Their prebuilt Tina model has a slit diffuser, but are currently sold out. You could buy their 65% acrylic diffuser case (here, $55 https://item.taobao.com/item.htm?spm=a230r.1.14.39.5e1b48a5xdwZcH&id=611155369436&ns=1&abbucket=16#detail) and use another set, but (likely due to coronavirus) they are only selling DIY kits at the moment.
