Author Topic: An easy way to install buckling springs (with video)  (Read 1662 times)
Offline sv650touring
« on: Sat, 21 March 2020, 13:33:13 »
If you want to skip the video, the trick here is to put the spring in a tube to prevent it from buckling while you are pressing it into place.
I have found very useful posts here before (for example, the correct pins to solder up a PS/2 cable rather than spending $20+ on an SDL cable), and when this method worked so easily for me, I thought maybe somebody here might find it useful too.
Offline OldIsNew
Re: An easy way to install buckling springs (with video)
« Reply #1 on: Sat, 21 March 2020, 14:55:56 »
Interesting, looks pretty neat and simple. Will have to try it and see how compares to the chopstick-o-death!
« Reply #2 on: Sat, 21 March 2020, 17:31:01 »
A few years ago there was another variant that, as I vaguely remember, used the shaft of a 1/4" pop rivet.
There really should be a place marker for these things.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline Maledicted
« Reply #3 on: Mon, 23 March 2020, 19:22:00 »
Great idea. I like it.  :thumb: Something like this would have saved me a lot of time trying to get all of the flippers on my new F77 to function. I wonder if Ellipse should consider adding this to his documentation.
