Author Topic: [IC] GMK Stealth  (Read 8274 times)
Offline Kappasike
[IC] GMK Stealth
« on: Wed, 01 April 2020, 22:55:59 »
This is a pretty basic set and if it goes to the GB stage will be pretty cheap. I'm not sure if this has been done before but it's just a black, dark grey, with red accents set. A very popular color for gaming products and looks pretty clean and simple. Surprised no one has done this before that I could find out about at least. No novelties for this set as this will be a relatively cheap GMK set.
239150-0
Might do an IC form letter depends on feedback. I'm aware this set isn't the best looking but it should be priced at around $100 if it does go live. Only kit will be base kit and maybe a spacebar kit.
« Last Edit: Wed, 01 April 2020, 22:59:09 by Kappasike »
Offline Slayer77
Re: [IC] GMK Stealth
« Reply #1 on: Wed, 01 April 2020, 23:17:42 »
Interested.
Sent from my GM1911 using Tapatalk
Offline Lil
    • designedbydark
« Reply #2 on: Thu, 02 April 2020, 02:55:20 »
https://geekhack.org/index.php?topic=85076.0
It might be a good idea to make changes to the colourway, since GMK Slasher has the same colours.
« Last Edit: Thu, 02 April 2020, 03:34:52 by Lil »
Offline huey
« Reply #3 on: Fri, 03 April 2020, 02:12:45 »
Oh man, just note that this is criticism and nothing against you personally. But, this is such a weak interest check.
- "I'm not sure if this has been done before but" There is an easily google-able webpage with most(if not all) previously run GMK sets. https://matrixzj.github.io/docs/gmk-keycaps
- The complete lack of renders and proposed kitting is worrying.
- I admire the fact that you want to make it cheap, but sticking just to a base kit(and maybe spacebars) might reduce the interest to buy outside 60% and up ANSI users(which is the majority I'd admit). This is particularly concerning when the only way you're going to make the set $100 is by having a 1000 MOQ.
- There is no mention of colours codes or chips what so ever. It would do you a lot of justice to look at what Pantone/GMK stock colours these proposed colours would match the best.
- As Lil says - GMK Slashers is already very close in relation to colours. You going to have to do something drastic to differentiate this set.
With that said, GL bud.
