Author Topic: Laser 2269 keyboard review (SMK 2nd gen Cherry mount)  (Read 8511 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Sat, 04 April 2020, 04:28:17 »
In this video we look at something a lot of people have asked me over the years; the Cherry-mount version of SMK clicky switches – in possibly its most well-known chassis. Hope you enjoy the video! :)
Offline mode
Re: Laser 2269 keyboard review (SMK 2nd gen Cherry mount)
« Reply #1 on: Sat, 04 April 2020, 05:43:27 »
Happy to see you cover these, i was curious how they are compared to the alps mount version.
Happily snapped up a few NOS :)
« Reply #2 on: Sat, 04 April 2020, 07:48:28 »
Excellent keyboard and would be one of my favorites if it had a more standard layout.
- Plato
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Sat, 04 April 2020, 13:17:02 »
You think the Monterey layout isn't standard enough? Oo
« Reply #4 on: Sat, 04 April 2020, 18:34:49 »
You're right. I have not had mine out in several years and I suppose that it wasn't really the layout that put me off of it.
To be honest, many of my "near-favorite but flawed" keyboards, like this one, have been boxed up tight and stored away for 5+ years, and I tend to forget exactly what is was that I didn't like about them. But I do seem to be able to remember what it was that I DID like about them.
- Plato
Offline diymkb
« Reply #5 on: Sun, 05 April 2020, 00:06:59 »
If I were to find the same keyboard and salvage the switches, would the SMK housings fit in most Cherry compatible plates?
Offline mode
« Reply #6 on: Sun, 05 April 2020, 00:56:54 »
You can just buy the switches NOS, no need to destroy a vintage board.
https://www.aliexpress.com/item/32764002294.html?spm=a2g0o.productlist.0.0.1420d1c6xZOGI9&algo_pvid=727970fd-3279-4035-9aed-71752df025d4&algo_expid=727970fd-3279-4035-9aed-71752df025d4-17&btsid=0b0a187b15860660697131903ef601&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
And yeah, cherry plates work for them, you just need to get a compatible PCB. https://www.lfkeyboards.com offers a couple.
Offline diymkb
« Reply #7 on: Sun, 05 April 2020, 05:47:56 »
Thanks for the link to the switches. I looked at the PCBs available on LFKeyboards, assuming I clip the two round protrusions on the SMK switches, would the metal contacts fit in Kailh hotswap sockets or in Mill Max sockets? I'm just trying to minimize my expenses by using parts that I already have on hand.
Offline mode
« Reply #8 on: Sun, 05 April 2020, 08:10:53 »
For the smaller pcb, yeah, the larger has holes so no clipping required.
The switches do not work with hot swap sockets.
Offline mode
« Reply #9 on: Sat, 25 April 2020, 06:19:15 »
My NOS switches turned up, they are indeed really nice. Honestly feel a bit smoother than my blue alps.
I’ll be saving them for a future project one day though, I’ll buy another lfkeyboards pcb to stash with them too.
Offline mode
« Reply #10 on: Sat, 25 April 2020, 08:08:41 »
Tried mounting a few keycaps to the loose switch and they're a bit hit/miss, SP SA went on just fine, but MT3 didn't fit, at least not without more force than I was happy to use.
I suspect the issue is the cross tip doesn't have a chamfer, so as long as it gets in, it shouldn't stretch them, but I didn't want to risk it by forcing.
