Author Topic: Leopold Numpad Sleeved Cable  (Read 3190 times)
Offline Ragsters
« on: Sun, 05 April 2020, 11:24:50 »
Hi guys!
I just bought a Leopold Numpad and wanted to know how I can sleeve the USB cable. You see this is a fixed usb cable with a internal plug like the one shown on the attached picture. Maybe I need to know the name of the connector so I can do better research? My goal is to have a 6" long aviator cable sticking out of it so I can plug it to the female counterpart in the color I please.
Offline rinkaan
Re: Leopold Numpad Sleeved Cable
« Reply #1 on: Mon, 06 April 2020, 07:51:46 »
it's a JST connector, but if you just want to get a cable, you can choose the PH/XH selection here from this chinese vendor on taobao...
but if it is a fun project have fun making cables! :)
Offline Ragsters
« Reply #2 on: Thu, 09 April 2020, 09:06:21 »
Hey thanks for the post. Do you have a link to the PH/XH selection you are speaking about?
Offline Ragsters
« Reply #3 on: Sat, 11 April 2020, 13:41:36 »
Is this the same connector as a Filco Connector?
Offline davek184
« Reply #4 on: Tue, 28 April 2020, 06:28:29 »
I just added a custom cable to that numpad. The connector is a Molex Picoblade 1.25mm pitch 5-pin with 28awg wire (I believe the official product number is 51021-0500).  I found a listing on ebay with 5 for under $5.   Good luck
Offline Ragsters
« Reply #5 on: Tue, 28 April 2020, 08:23:05 »
Thank you so much! This is the info I was looking for. Have any pics of your mod?
Offline davek184
« Reply #6 on: Tue, 05 May 2020, 09:43:04 »
Here is a photo.241667-0
Offline Ragsters
« Reply #7 on: Wed, 06 May 2020, 10:59:59 »
That looks amazing!! Do you have a build log? Can you link me the parts?
