Author Topic: Compaq Portable III  (Read 3665 times)
Offline Kirbyzuto
Compaq Portable III
« on: Sun, 05 April 2020, 19:58:07 »
I was given a Compaq Portable III Keyboard from my girlfriends father, and have hard time figuring out what switches it has inside. Any information would be greatly appreciated.
Offline flurryvelvet
Re: Compaq Portable III
« Reply #1 on: Sun, 05 April 2020, 21:08:26 »
It's likely a foam and foil type of switch.
Offline Kirbyzuto
« Reply #2 on: Mon, 06 April 2020, 00:09:26 »
Thats the thing it's a white alps switch but I cant figure out what kind
Offline envyy24
« Reply #3 on: Mon, 06 April 2020, 03:30:01 »
A picture can really help here friendo.
Offline Kirbyzuto
« Reply #4 on: Mon, 06 April 2020, 18:02:59 »
You know, never have I missed my brain cells more than now, sorry for not posting a photo.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #5 on: Mon, 06 April 2020, 18:21:51 »
Looks like SKCM Damped whites to me https://deskthority.net/wiki/Alps_SKCM_White_Damped, but possibly could be SKCM whites https://deskthority.net/wiki/Alps_SKCM_White. Are they clicky or tactile & not to loud? You could also check by opening one of the switches up, this video will show you how if you do not know already, https://youtu.be/RnvC80Vjuts?t=150. Then if the slider/stem has black rubber strips in the sides that move along the housing they are damped tactile whites, if the slider/stem is just all white they are regular clicky whites.
Offline Kirbyzuto
« Reply #6 on: Mon, 06 April 2020, 18:42:05 »
They're fairly clicky, I'll pop one open to take a look, thanks for the information.
Edit: Just popped one open and it did not have any rubber inside of it, thanks again for the info as to how to identify them.
« Last Edit: Mon, 06 April 2020, 18:53:02 by Kirbyzuto »
Offline Rob27shred
« Reply #7 on: Mon, 06 April 2020, 19:09:33 »
Yep no problem! Also the fact they are regular whites is a good thing. They are much more sought after & are from an earlier gen of ALPS SKCM switches that had thicker housings possibly made from a different plastic. Definitely superior to damped whites!
Offline Kirbyzuto
« Reply #8 on: Mon, 06 April 2020, 19:33:40 »
More information that I had not known prior, although might I ask what makes them sought after? I have not dwelled in vintage keyboards much.
Offline Maledicted
« Reply #9 on: Mon, 06 April 2020, 21:56:00 »
Alps clickies are the most sought-after Alps switches, and amongst the most sought-after vintage switch (far superior to anything made today in my humble opinion). SKCM blues take the crown there, but ambers and whites don't trail too far behind. Blues basically had incremental changes until they were superceded by whites. In this way, early whites aren't much different from late blues, and feel/quality is thought to have degraded through each change as the years went by.
Keep them clean, and I mean even cover them when not in use. If they get dirty/dusty, they'll start to feel terrible.
Offline Kirbyzuto
« Reply #10 on: Mon, 06 April 2020, 22:14:16 »
Have seen a lot of praise for SKCM Blues and Ambers, never much talk about whites in most other mech keyboard forums, thanks for the insight on the story of whites. :)
Offline Maledicted
« Reply #11 on: Tue, 07 April 2020, 00:36:08 »
You don't hear much about whites because they're newer than blues and ambers, and way more common. You can find 15+ boards full of them on Ebay at any given time. They were prolific throughout the late 80s through the mid 90s. That in no way diminishes their inherent value as a fantastic clicky switch, when in good shape.
You're very welcome.
Offline envyy24
« Reply #12 on: Tue, 07 April 2020, 04:58:00 »
No the other two are rarer, but the white SKCM alps, in your case even pine grade, is in no mean not good. They are just very common, people normally can have easier access to them, comparing with the like of blue alps or orange alps. I think some says white is almost 80-90% like blue
« Last Edit: Tue, 07 April 2020, 05:00:13 by envyy24 »
