Author Topic: KEYTRONIC KB w/ TRACKBALL $19.95 (+$18.80 ship for me)  (Read 3721 times)
Offline TexasFlood
« on: Sun, 27 June 2010, 20:41:53 »
Any info on this keyboard?  Might be a nice location for a trackball.  Probably a crappy rubber dome but the positioning of the trackball caught my eye.
« Last Edit: Sun, 27 June 2010, 22:10:15 by TexasFlood »
Offline spolia optima
« Reply #1 on: Mon, 28 June 2010, 03:33:49 »
Looks like a Trackball-U1:
http://keytronic.com/home/products/specs/trackball-u1.htm
It's a rubber-dome-over-membrane setup, but then again it's key tronic so it's gotta be decent.
keyboards!
Offline aegrotatio
« Reply #2 on: Mon, 28 June 2010, 11:18:33 »
Yes, not a "crappy rubber dome" by any definition.
These are good keyboards.
I'm typing on one now (sans trackball).
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline EverythingIBM
« Reply #3 on: Mon, 28 June 2010, 15:23:59 »
The "lifetime series". Hmmm... must last a lifetime then.
« Reply #4 on: Mon, 28 June 2010, 15:46:20 »
Quote from: EverythingIBM;197308
The only time when any of my Keytronic keyboards (I have gone through a few) have failed have been when I have cleaned them from crud and accidentally left some water inside a plastic crevice. The most-used keys may be a little weaker than some of the keys that I hardly ever use on the keyboard but they are still more sturdy and with better feel than the keys on the brand new Dell keyboard that I use at work.
Offline ricercar
  • mostly abides
« Reply #5 on: Mon, 28 June 2010, 15:53:34 »
This is the only rubber dome keyboard that remains in service in my home theatre media PC. Many folks think Keytronic are the only worthy rubber dome this side of Topre.
These retail for $80 and are often available in black. Often you can find them for cheap by buying the floor model after the trackball is lost; I just pop in a shooter marble and voila.
« Reply #6 on: Mon, 28 June 2010, 16:09:25 »
Quote from: ricercar;197319
I think my KB-8923s would be better than those keytronic rubber domes.
Offline itlnstln
« Reply #7 on: Mon, 28 June 2010, 16:11:38 »
My GF says these are better:
Offline itlnstln
« Reply #8 on: Mon, 28 June 2010, 16:24:15 »
That must be the secret.  If you're going to go cheap, go all-the-way cheap.  All the cheapness then coalesces into magic... or a belief that all that ultra-cheapness is somehow better than stuff that costs money.
« Reply #9 on: Mon, 28 June 2010, 16:27:11 »
Quote from: ripster;197350
Like men who think marrying will save them money due to the tax break.
HAAHAHAHAHAHAHAHA!
That's one reason not to get married...
Offline Voixdelion
« Reply #10 on: Tue, 29 June 2010, 02:35:59 »
RE: trackball positioning -
Depends on how you are at nav with your thumbs.  I found the similar placement of the trackball on the focus-7200 similarly appealing, but it turned out to be better in theory than in practice.  Most comfortable positioning for me is still above the arrow keys as on the M5-1.  Why this was not oft imitated I do not understand; it makes a great deal of sense.
"The more you tolerate each other, the less enforcement will happen."-iMav
« Reply #11 on: Tue, 29 June 2010, 04:37:47 »
Quote from: ripster;197341
Even my cheapo $10 Logitech at least had a metal plate and tons of screws.
All of mine have lots of screws, but I guess they are old enough. Even a flimsy kb can have good feel -- just look at what people are saying about the Chicony's with imitation blue cherries.
One thing that I think sets KeyTronic apart from many other rubber domes is that the key stems are sturdy and don't rattle that much. That may contributes quite a bit to the feel..
« Last Edit: Tue, 29 June 2010, 04:39:49 by Findecanor »
