Author Topic: realforce keycap height  (Read 2566 times)
Offline rf86u
« on: Sat, 11 April 2020, 10:08:01 »
are r1 and r2 same height?
and r4 r5 same height?
« Last Edit: Sat, 11 April 2020, 10:16:27 by rf86u »
Re: realforce keycap height
« Reply #1 on: Sat, 11 April 2020, 11:07:53 »
Function row and Number row both use the same profile, yes, and
Bottom alphabetic row and Space bar row both use row the same profile.
("Row 1" often means the numeric row, with "Row 2" the row with the "QWERTY" keys ... but there are multiple ways to count keyboard rows)
« Last Edit: Sat, 11 April 2020, 11:17:44 by Findecanor »
Offline rf86u
« Reply #2 on: Sat, 11 April 2020, 11:25:02 »
Thank you this makes it a bit easier to do key swap
