Author Topic: 60% keyboards that can program (alt + 4) to function as (alt + f4)  (Read 7348 times)
Offline .
Are there 60% keyboards out there that can do such things?
« Last Edit: Sun, 12 April 2020, 09:25:58 by . »
Offline Sup
Re: 60% keyboards that can program (alt + 4) to function as (alt + f4)
« Reply #1 on: Sun, 12 April 2020, 10:08:07 »
Any QMK compatible keyboard yes. You just have to program it
current
Coming soon
Offline .
« Reply #2 on: Sun, 12 April 2020, 10:26:05 »
Are there hot swappable QMK compatible 60% keyboards out there?
Offline DoctorNunu
  • Masterworks
« Reply #3 on: Sun, 12 April 2020, 15:52:48 »
Check out KBDfans if you're looking for something hotswappable and if you're on a budget. I believe all their pcb's are QMK compatible.
Offline .
« Reply #4 on: Sun, 12 April 2020, 21:42:15 »
Do they ship items from Europen warehouses so I don't have to pay import duties?
Offline DoctorNunu
  • Masterworks
« Reply #5 on: Mon, 13 April 2020, 04:27:05 »
Unfortunately not, if you want to check out European stores then check out mykeyboard.eu and candykeys.com.
