Author Topic: some recommendations on 65/60 keyboards?  (Read 1694 times)
Offline KRMing
« on: Mon, 13 April 2020, 05:53:51 »
Hi, I'm looking for a compact keyboard with 60/65 layout(hhkb is fine also), are there any recommendations?
It would be great if the keyboards match the following conditions.
1. Compact housing(no big margins on any side)
2. Full-aluminum housing
3. Brass plate option?
4. Hot-swap PCBs
I've found some keyboards that are available right now like the RAMA Jules, 7V, Graystudio Space65, but these aren't quite appealing.
Also, don't mind the budget(unless it's over $1K) so no need to be overly cheap :)
I wish I could have joined the GB on No.1 65 by Keycult or the Canoe :(
Are there any upcoming GBs that may fit my standards? Plz help a newbie out. Thx for reading.
« Last Edit: Mon, 13 April 2020, 05:55:31 by KRMing »
Offline typo
Re: some recommendations on 65/60 keyboards?
« Reply #1 on: Tue, 14 April 2020, 00:44:03 »
KBDFANS, DROP ALT, but is sounds like you want something way above those. I can attest Rama is very nice. Although I have the KOYU which seems what you want. I believe it is long since sold out. Which is why I paid a fortune for mine. Drop Alt is honestly good if you put a brass plate on the bottom and KAT key caps are a bit better than the ones it comes with. Do not buy key caps from Drop! They just throw them all in a bag.
Honestly all the boards you picked are grail.
However If typing was what I was actually concerned about I would get a HHKB and have a titanium CNC case built. Which I have also done.
Offline KRMing
« Reply #2 on: Tue, 14 April 2020, 03:48:10 »
Thx for the reply. I should just wait for a decent 60/65. Until then, I'm just planning on fixing my current 87 keyboard. Tealios switches make some noise on the contact points, maybe should sort out another batch and lube them.
Offline walie
« Reply #3 on: Tue, 14 April 2020, 09:13:05 »
They do not. And no you haven't
