Author Topic: Model F AT - Yes! It has an F11 key.  (Read 3408 times)
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« on: Mon, 28 June 2010, 14:19:47 »
It's blocked by the enormous + key.
More details later.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Mon, 28 June 2010, 14:58:15 »
You split the num pad + in 2? You should try some of the Shift's and the Enter's next and see what you get.
Offline HaaTa
  • Kiibohds!
« Reply #2 on: Mon, 28 June 2010, 18:48:55 »
Oh, I've already done that :P
Left shift gives you Hiragana/Katakana switch.
Right shift is a mystery key.
Kiibohd
Offline didjamatic
« Reply #3 on: Mon, 28 June 2010, 23:15:17 »
Want to sell your + key?  Doubtful, but figured i'd ask.  I might be looking for one of them as well as an Alt key and possibly others for a PC-AT board.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #4 on: Tue, 29 June 2010, 11:11:29 »
One would have thought that the key in question would have a scan code of 7B, which would be hard to confuse with 56, the scan code of the F11 key.
Offline JohnElliott
« Reply #5 on: Tue, 29 June 2010, 14:55:45 »
You can see the scancodes for all the extra positions on my site. The one under keypad + sends 78, which translates to 57, F11.
Offline phoenix
« Reply #6 on: Tue, 29 June 2010, 15:14:40 »
Quote from: JohnElliott;197703
When I tested mine, the two contacts under the spacebar had no response at all, but I was connecting through a blue cube. Can you confirm that they indeed send scancodes over ps/2? Do you know what USB adapter will send scancodes for those two?
Offline JohnElliott
« Reply #7 on: Tue, 29 June 2010, 15:39:45 »
Quote from: phoenix;197708
That's how I tested them: under DOS, with the keyboard plugged into a PS/2-equipped motherboard.
I don't know if any USB adaptor will support those scancodes; it strikes me that one which allowed the translation to be customised would be a useful thing to have.
