Author Topic: Razer Orbweaver with Hasu USB-to-USB Converter  (Read 48075 times)
Offline BIZ!
  • It's gonna be great!
« on: Thu, 16 April 2020, 20:10:21 »
I'm trying to use the Hasu USB-to-USB Controller Converter with the Razer Orbweaver to circumvent Razer's Synapse software:
https://www.1upkeyboards.com/shop/controllers/usb-to-usb-converter/
I've used kaiibod before with the ergo dox but macro use is throwing me with the TMK and QMK editors available for the Hasu controller. Any suggestions?
Here's my breakdown:
HASU KEYBOARD COMMAND DEFAULT with Orbweaver attached (5x4 keypad):
`     1.    2.    3.    4
Tab.    Q.     W.    E.    R.
Caps Lock.    A.    S.     D.     F.
Shift.    Z.    x.    C.    v.
Thumb key =. Option
Thumb flap=   space bar
Thumb directional toggle:
Away= up arrow
toward= down arrow
Up = left arrow
down= right arrow
 SYNAPSE KEYS WANTED (5x4 keypad)
Layer1:
F1     F2.    F7.     F8.    F9
Z.     x.      e.      O.       ‘ apostrophe
H.    J.    K.    L.    ; semicolon
Shift.    Alt.    B.    Command+Z.    Down arrow
Thumb key = keymap 2
Away= T
toward= G
Up = command+A
down= shift+command+A
LAYER 2:
F3      F4.    F5.     F6.    Shift+F4
5.   Y.     Q.    W.     6.
M.    ,comma    k.     . period    /
Alt+C.    Command+Tab.    Shift+F1.    Shift+F2.    ]+NpdENTER
Away= T
toward= G
Up = command+A
Ducky Shine 3 |  IBM Model M  | Razer Orbweaver  | ErgoDox Infinity
Offline downysoft
Re: Razer Orbweaver with Hasu USB-to-USB Converter
« Reply #1 on: Fri, 26 February 2021, 02:02:45 »
DISCLAIMER:  I'm new, so this might be widely known or even a bad idea for some reason.
If you get a peripheral working on a Raspberry Pi device, you can set it to "keyboard passthrough" and use it just like a plug and play keyboard.  It could be a way to bypass manufacturer software.
This looks like a good thread to start research:
https://www.raspberrypi.org/forums/viewtopic.php?t=263356
Offline BIZ!
« Reply #2 on: Sat, 12 March 2022, 00:24:18 »
I appreciate your reply. I hadn't thought of that approach.
