Author Topic: Has anyone here made their own per key RGB PCB?  (Read 2599 times)
Offline Chief_Sloth
« on: Thu, 16 April 2020, 22:10:31 »
I want to learn to make one but only if people have made their own, they seem to be hard to find, and it sounds fun to learn while I have nothing to do.
Offline Chief_Sloth
Re: Has anyone here made their own per key RGB PCB?
« Reply #1 on: Thu, 16 April 2020, 22:42:18 »
Also, I think I am really bad at using the search function. I am having a hard time finding anything at all on it LOL
Offline fpazos
« Reply #2 on: Fri, 17 April 2020, 01:28:19 »
Maybe you can use one of these as reference https://github.com/BenRoe/awesome-mechanical-keyboard/blob/master/docs/README.md
Good luck with your proyect.
Enviado desde mi Redmi Note 7 mediante Tapatalk
« Reply #3 on: Fri, 17 April 2020, 05:54:01 »
You could look at the schema and parts list for Input Club's K-Type. (but for your sanity's sake, avoid looking at the PCB layout... :-þ )
Massdrop CTRL is the same keyboard in a different colour scheme.
