Author Topic: [IC] Infinikey PBT Crisp  (Read 8656 times)
Offline Dazon
« on: Fri, 17 April 2020, 18:13:19 »
Welcome to PBT Crisp!
This is the IC of Infinikey PBT Crisp, as you have probably guessed. This is a set based on a certain special cat from a certain special game. I won't be mentioning that game or that cat's name because I would like to avoid all possible lawsuits.This is a set based on Raymond from Animal Crossing: New Horizons. The modifiers are the colors of his glasses and the alphas are the color of Raymond. The modifier legends are colored off his heterochromia. The alpha legends are the color of his hair. The name is based off his initial phrase "crisp".
Colors
240146-0
Kits
Base Kit
240148-1
Mega Add-On Kit
240150-2
TODO:
  • Make Novelties
  • Make Deskmats
  • Find Vendors
  • Make Renders
History:
April 17: Initial Post
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #1 on: Fri, 17 April 2020, 18:51:07 »
Let the criers proclaim:
The season of Anime sets is over!
Now is the season of AC:NH sets!
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline Inner-Ear
Re: [IC] Infinikey PBT Crisp
« Reply #2 on: Fri, 17 April 2020, 19:02:54 »
Really nice to see more dark themed PBT sets. We need more of them.
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #3 on: Fri, 17 April 2020, 19:13:03 »
I like it; INTERESTED!!!
Offline Motte
« Reply #4 on: Fri, 17 April 2020, 19:18:18 »
Wow that green! That's the cats pyjamas :D Would you add a kit with german alphas?
Offline krikun98
« Reply #5 on: Sat, 18 April 2020, 03:30:53 »
The writing on the "Lower" key is bigger than the keycap.
Offline Vireca
« Reply #6 on: Sat, 18 April 2020, 04:42:00 »
I really like it, but I like it more the green than the orange. Just the kit in that oblivion color and green mods will be amazing
Offline depletedvespene
    • Keyboard-related resources.
« Reply #7 on: Sat, 18 April 2020, 21:59:37 »
Interesting choice of colors (although I like the amber better than the green, but that is strictly subjective).
It's obvious this set is following Infinikey's base template for both kits, but there are several changes in the alphas that call my attention as clearly erroneus:
- In the base kit, the R3 \| key (which other Infinikey kits have as #~) is presented as `~ , which makes no sense.
- In the add-on kit, the R1 1¬ key should be `¬ instead. The R3 \| key should be #~ instead.
Offline sirieous
  • help
« Reply #8 on: Sun, 19 April 2020, 00:04:10 »
cute idea
Offline BMO
    • My Design Portfolio
« Reply #9 on: Sun, 19 April 2020, 12:41:20 »
Really fits Razer's aesthetics, which isn't bad!
Lovei it! Personally would love ot have an arrow kit available
Also, you should make this razer compatible since they don't have a standard bottom row.
Offline Dazon
« Reply #10 on: Mon, 20 April 2020, 16:44:02 »
Ah, yes I'll fix these, thanks for bringing them to my attention!
Sent from my SM-G973U using Tapatalk
Offline Dazon
« Reply #11 on: Mon, 20 April 2020, 16:46:01 »
thanks!! by arrow kit, do you mean a kit with the other colors? if so, I'll try to make it happen. as for razer layouts, it is possible if you buy the mega addon kit. there is 6u spacebars in there, and the non standard keys are in the base kit.
Offline BMO
« Reply #12 on: Tue, 21 April 2020, 06:27:49 »
Not necessarily other color, I just love combining it with my set. But buying the whole base kit would be to expensive for that.
I think modifiers kit would fit better in that context.
Aah, would be cool to have this kit :)
Offline Dazon
« Reply #13 on: Tue, 21 April 2020, 18:54:47 »
ah, I think you mean a separate kit with just the arrows to use on another set. I could look into that, but there would have to be high demand for such a kit.
« Reply #14 on: Tue, 21 April 2020, 18:55:35 »
underrated post
Offline Dazon
« Reply #15 on: Tue, 21 April 2020, 18:56:32 »
underrated post
so far there havent been too many. I hope that there arent many though, because it will get old fast
