Author Topic: Recommend me a 65% - 80% keyboard  (Read 1721 times)
Offline Ragsters
« on: Sat, 18 April 2020, 12:01:35 »
Hello,
I'm looking for a white, classic looking keyboard. It does not need keycaps. Something like the Doro 67. Can you guys suggest something that is available or worth waiting for?
Offline HungerMechanic
Re: Recommend me a 65% - 80% keyboard
« Reply #1 on: Sun, 19 April 2020, 12:28:22 »
Leopold tends to have factory keyboards available in off-white colours such as eggshell or cream whites, if that's what you're looking for.
If you're looking for more of a bright milky white, Varmilo has that.
The JER-A06 / J80 is being run around this time, with at least one 'classic' white option. And some people are selling their slots for E-white on the E8.5 GB.
Offline Ragsters
« Reply #2 on: Sun, 19 April 2020, 14:35:25 »
Thanks for the reply! The "classic" that I was referring to is the bezel/case not the color of white. I really do like both of the boards (E8.5 and Jer-A06) you suggested. Do you have some links? People who are selling slots?
« Reply #3 on: Sun, 19 April 2020, 20:53:22 »
Here's the link to the J80 buy, comes in e-gray or e-milky white:
https://geekhack.org/index.php?topic=105121.0
Hard to get slots. Check the thread, I think it's basically some kind of raffle to get a slot?
You can find a couple people selling their E-white slots on the E8.5 on this page of the thread:
https://geekhack.org/index.php?topic=103520.200
Just PM them, or post there indicating that you would like to buy an E-white slot.
