Author Topic: Greetings from Eugene, OR!  (Read 2652 times)
Offline darqueskye
« on: Sun, 19 April 2020, 05:59:13 »
It all started with a several-year-old Cooler Master CM Storm Quick Fire Pro. Little did I know what I was getting myself into.
It began a couple weeks ago or so when I finally decided my keyboard needed replacing. It was...old, anyway, and sure it functioned fine, but it was big and clunky and not remotely aesthetically pleasing; it was a giant black plasticky monstrosity and the backlight only came in red and (by design) illuminated less than half of the keys.
So off I went to consult the interwebs and do some research. I knew I wanted something Bluetooth flavored so I would stop tripping over the cable all the time, and I knew I wanted something backlit so I could see the keys in the dark. I had little idea about size; I learned I didn't like MX Brown switches, but I knew virtually nothing about those, either...
...So I thought I would just look at, say, Logitech to see what they had on offer. I discovered I really liked a lot about the G915, but I tend to be skeptical (fairly or not) about in-house switches -- since I had little experience beyond Cherry MX Browns I decided I would like the hot-swap option -- and I ended up scoffing to a friend about the idea of trying to justify $250 for a keyboard. Well. As it happens he's a tech guy, and has spent quite a lot of time and money on keyboards. So he threw out a few names, sent me a few links (this site being one), and, with some shepherding, sent me on my merry way.
Fast forward several days of hyperfocus and a multitude of hours spent rooting through the MKB rabbit hole. Here I stand (or...sit, as it were), my mind reeling with the sheer variety, bare as the proverbial babe I am. I know I still know very little about the arcane world of keyboards and their sundry components (I do now know I like the sound clicky switches make), but I definitely look forward, as I begin my time here, to wherever this will lead, and I know I will be in good company.
I only mourn the inevitable loss of my wallet.
Offline Maledicted
Re: Greetings from Eugene, OR!
« Reply #1 on: Mon, 20 April 2020, 15:55:46 »
Welcome to Geekhack darqueskye. I have heard mixed things about Logitech's Romer-G switches (never tried them myself). Logitech is probably the way to go for anything wireless though.
What about the sound of clickies do you like? There aren't many different sounds for them with modern switches, although that is slowly changing. With something like a Cherry MX blue, it sounds kind of like crumpling plastic grocery bags to me (it used to sound good). Most are high-pitched, some like Kailh box jades, and pinks, are pleasantly crisp and bassy. If you really get into clickies, you might want to start looking to the past with IBM's capacitive buckling spring, Alps SKCM, Space Invaders, and even NEC blue ovals.
Offline darqueskye
« Reply #2 on: Thu, 30 April 2020, 19:29:12 »
Hey, thanks Maledicted! Apologies for the belated reply!
To be honest, I don't really know what qualities about the sound of clickies I like in particular, apart from the aural feedback. Due to what little experience I have, though, I'm thinking about picking up a clicky switch tester so as to get a feel for what other options there are. Eventually I'd like to build my own, so that knowledge will come in handy.
With regard to the Logitech board, it wasn't something I was particularly set on; it just had qualities I was looking for (e.g., backlit keys and Bluetooth). I was skeptical about in-house switches, though, and I think largely through my particularity I ended up here. Lol. On that note, I ended up buying the Keychron K4. I had actually written a lengthy review here about it but figured it would be better suited to the 'Reviews' thread, so I'll post it there. : )
So again, thanks for the welcome!
Offline Maledicted
« Reply #3 on: Thu, 30 April 2020, 19:48:46 »
You're welcome, and it is no problem at all. I don't like seeing new member posts with 0 replies just sitting there. I don't really care much if anybody responds to me anyway, just that they get some kind of welcome.
Switch testers are always a great idea. Make sure it has some box switches in it. I think you'll find one you like.
There seems to have been a lot of buzz around the Keychron offerings, and it makes sense. That K4 looks to have a lot of great features for the price, especially with that aluminum frame option. I'll have to go see the review.
Offline darqueskye
« Reply #4 on: Thu, 30 April 2020, 22:35:56 »
Before I decided on the K4 I was actually looking for something with hot-swap switches specifically because I was really curious about the Kailh switches. Lol. I'm actually really curious about the BOX Jade/Navy and the Speed Bronze. A hot-swap PCB is definitely something I'll be looking for as I piece together my ideal kit down the road so I can try them out and see what I like best. : )
Offline Maledicted
« Reply #5 on: Thu, 30 April 2020, 22:56:55 »
I see mention of speed bronze everywhere, all of the time. I need to try those as well if only to see what all of the hype is about. Hot swap boards are always a good idea for that reason. I have yet to own one myself, as the parts are stuck in Chinese customs purgatory.
Offline darqueskye
« Reply #6 on: Sun, 03 May 2020, 05:55:59 »
Ugh, that's the worst. Understandable right now, but it sucks nonetheless. Hopefully it starts to move in relatively short order! Which board did you get?
Offline Maledicted
« Reply #7 on: Sun, 03 May 2020, 18:20:21 »
I ordered a DZ60. I couldn't find one with mini usb that came with the hot swap sockets installed, so I ordered those separate. Ordered a brass plate and walnut case.
I doubt it will. I'm no no hurry anymore, as the new Kailh box silent reds I ordered to try in it were somehow returned to sender, so that whole process is starting over anyway.
