Author Topic: black or white  (Read 1841 times)
Offline TheNajin
black or white
« on: Mon, 20 April 2020, 02:56:04 »
which one u like most?
钻满堂 Four of Diamonds | Custom Keyboard Studio
Offline el_murdoque
Re: black or white
« Reply #1 on: Mon, 20 April 2020, 07:59:15 »
I'd ask if I could get the white one with all white keys.
Or I'd try the white alphas on the black board, but all in all, I don't really dig that super hard contrast.
Offline typo
Re: black or white
« Reply #2 on: Thu, 23 April 2020, 22:50:01 »
Indeed. white on white is stunning and most do not have it. Unique. Get the Corsair key cap set if MX. They are awesome caps1 2.35MM thick PPBT! It is way better than SP! Is the board backlit? They shine through too, very well. this would look incredible and the quality of the Corsair is second to none if you have MX stems. Only issue is i am not sure if it has a small right shift key if you need that. It might though. The fonts, not sure if you like them but they are highly readable. the set is dirt cheap too. Do not let that mislead you though. Best of luck to you!
Offline senjo
Re: black or white
« Reply #3 on: Fri, 24 April 2020, 03:50:14 »
white
Re: black or white
« Reply #4 on: Fri, 24 April 2020, 07:26:32 »
I like all white keys in a black case, or vice versa.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Re: black or white
« Reply #5 on: Fri, 24 April 2020, 07:47:46 »
Is that closer to WS1 or WS2 (render of GMK Bleach?) in the first image?
FWIW if you are deciding on e-white IMO very few sets will look good on it. All other keycaps that have warmer tone white will look slightly off. Way more keysets go with black.
I'm not saying this is a bad thing, I like e-white which is why I went in on GMK Bleach.
