Author Topic: Model 3d keyboards  (Read 3975 times)
Offline chimera15
Model 3d keyboards
« on: Tue, 29 June 2010, 09:26:41 »
Building my scratchbuilt I find I'm to a point that I need to mock up a 3d or at least a 2d layout that can be used to machine parts, and I can show to people.
Does anyone know an existing free 3d mechanical board that I might be able to modify?
http://www.the3dstudio.com/product_details.aspx?id_product=39716
I see a lot of rubber dome 3d junk, but almost no mechanicals.  Having an existing 3d switch or even cherry caps for instance would be helpful if nothing else.
hmm..
http://sketchup.google.com/3dwarehouse/details?mid=3f34b7f6ef1fd8e7891aaffa5a7c7cad
Also, does anyone have any suggestions or that has used cnc what the best format would be?   For instance if I do mock something up is it possible that the machinist would be able to use my 3d files to directly machine the part?
Are these measurements in mm, they don't seem to match the measurements I've taken..hmm.
Oh I see the holes are 14mm which was my measurement. The switch is 15.6 mm width.
http://www.cherrycorp.com/english/switches/pdf/keyswitch_cat.pdf
« Last Edit: Tue, 29 June 2010, 09:38:00 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
Model 3d keyboards
« Reply #1 on: Tue, 29 June 2010, 09:33:37 »
Alps boards:
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Model 3d keyboards
« Reply #2 on: Wed, 30 June 2010, 05:16:33 »
Seems like there aren't any.
If everything fails, you could still try asking lowpoly.
Offline imsto
    • imsto.cn
Model 3d keyboards
« Reply #3 on: Wed, 30 June 2010, 08:29:31 »
mm?
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline rantenki
    • http://armyofevilrobots.com/
Model 3d keyboards
« Reply #4 on: Wed, 30 June 2010, 23:47:32 »
Quote from: chimera15;197540
I do _everything_ in solidworks, which can export pretty much any imaginable format. I used MastercamX (old and crappy) for the CNC G-Code part.
I have 3d models of the Cherry mx switch (accurate enough that my parts all fit when I assembled them). PM me your email and I will send them.
You may wanna try out shapeways.com for 3d printing, coz you can get a lot more creative with the design of the casing.
Basically, as long as you get the spacing right, the rest of the job is pretty easy.
The PCB design job is a lot more difficult.
Offline aegrotatio
Model 3d keyboards
« Reply #5 on: Thu, 01 July 2010, 13:03:22 »
Wow, isn't Solidworks expensive?  I priced it once, long ago...
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
