Author Topic: Request for help on my first build!  (Read 1303 times)
Offline ab2k18
« on: Mon, 20 April 2020, 20:14:03 »
Hey geekhack,
I was wondering if I could get some help from you guys for my first build?
I’d like to make the following:
XD68 size (dedicated arrow keys)
Apple style keycaps (ie Apple font, command button, etc. Like the Apple Extended Keyboard II)
Wooden case
I have attached an image of a smaller size custom keyboard that is close to the look I’m going for!
Grateful if you could suggest places to buy the parts I need. I already have an AEK II, but I discovered it doesn’t use MX switches, so I may have to buy 3rd party caps, which is fine by me. It also doesn’t have a smaller right hand shift key, so I don’t think using these caps would be an option for me anyway?
Thanks again!
