Author Topic: Hi Geekhack!  (Read 2481 times)
Offline econeuler
Hi Geekhack!
« on: Thu, 23 April 2020, 16:35:40 »
Hi!
I'm very glad that there are people in the world like you guys, who build communities like these, truly awesome!
Been typing on a Pok3r for far too long and have the plan to upgrade with some ongoing GBs.
Trying to figure everything out, how this hobby works, and planning the following: Decent 65 with Holy Panda switches.
Cheers from Sweden!
Offline Maledicted
Re: Hi Geekhack!
« Reply #1 on: Fri, 24 April 2020, 13:08:12 »
Hi enconeuler. Welcome to Geekhack.
What's wrong with the Pok3r, just want something fresh?
I haven't heard anything bad about the DZ60 pcb. I'll assemble my first LEGO board with a DZ60 in 65% configuration, with a walnut case. Might as well just make it your own if you want something that small.
Offline econeuler
Re: Hi Geekhack!
« Reply #2 on: Sat, 25 April 2020, 07:48:16 »
Thank you :)
Nothing is wrong with it, it is a nice keyboard. In fact I have converged to smaller boards over time (mostly use Vim so don't really need a large set of additional keys, and closeness to Esc is nice). However, as you say, I'm interested in something fresh and also the enjoyment of customizing something. Also, going to try to the switch from iso to ansi (when not writing specifically in my native language)
I see! Yes, I don't know about the pcb more than the GB says "1x TA65 v3 PCB by Maartenwut", searching I found [this](https://maartenwut.com/product/ta-65-rev3/).
Offline Maledicted
Re: Hi Geekhack!
« Reply #3 on: Mon, 27 April 2020, 10:54:54 »
Thank you :)
You're very welcome.
Really? A switch to ANSI? Is this actually an ergonomic thing, or for the sake of a broader set of options in caps, etc? I never could understand the purpose of the ISO layout myself. It also seems to me though that we may have stuck with the big ass enter keys and made everybody happy, however.
That looks to have some nice features, . I'm not a fan of USB type C myself though. I work as a tech in schools and I have seen enough of those fail already in the first year of having them on teacher and student laptops to say I'll be staying away from them when I can.
If you're considering that PCB pretty seriously, I would ask about it in the keyboards section of this forum. I don't plan on doing a lot of the LEGO thing myself, and there are people with a lot of experience with it, and even in designing PCBS who are more likely to see it there and hopefully weigh in on it for you.
Offline econeuler
Re: Hi Geekhack!
« Reply #4 on: Wed, 29 April 2020, 04:13:17 »
I see a lot of positive things with switching to ANSI. For starters I work mostly in English, and it can go weeks working on my desktop before I write in Swedish (and need å, ä, and ö). Most conversations in my native language is by phone. So by switching to ANSI, it is easier to write in English, which I do most often. Further, I work with programming and the []{} keys are semi awkward on ISO. So I believe that ANSI is better for all situations, as long as you don't need another alphabet! I will still have my ISO keyboards, and use them for when I need to write in Swedish.
Hmm, that is very interesting! I only use USB-C for my phone, my keyboards have had mini or micro USB. I like mini usb, but micro is also too prone to break.
I actually already ordered 2 of those in the Decent 65 GB (one with the board + extra pcb/plate), but I'm sure it will turn out perfectly!
The only project I consider buying another pcb for, is: I have an Vortex Race3 that I don't use, and I want to desolder it change switches, and build a wooden case for it. But I don't really like tht pcb, micro-usb and too few stabs. But, I'll have to think about that.
Offline Maledicted
Re: Hi Geekhack!
« Reply #5 on: Wed, 29 April 2020, 08:59:15 »
That all makes sense. The ISO enter key is what always bothered me, but I haven't used many ISO boards, and not for very long periods of time.
I agree completely. Mini USB should have stayed the standard, at least until they started deciding to try to make some wonder all-in-one interface with type C. Micro may literally be the very worst, but unless somebody has done some heavy testing with type C, time will tell.
If you go down to a 65% (I imagine you want the arrow keys) with the DZ60 pcb, you can get those boards with mini usb, and there are commercially-available wood cases for them to boot. That's what I'm going with. If you're going custom with the Race3, you could always just get a panel mount mini usb cable to splice up, like this:
I go to the extreme when I modify a board I really like and mount a huge GX12 aviator female socket to the case, and make a USB Type A to GX12 cable to go with it:
« Last Edit: Fri, 01 May 2020, 15:15:07 by Maledicted »
Offline econeuler
Re: Hi Geekhack!
« Reply #6 on: Fri, 01 May 2020, 10:38:59 »
Wow! That is really nice!  :thumb: Thanks for the idea, that is definitely an option for my mod of the Race3!
Offline Maledicted
Re: Hi Geekhack!
« Reply #7 on: Fri, 01 May 2020, 15:18:38 »
Thank you very much, and you're welcome. I'm always glad to see more people putting aviator connectors to good use, instead of just giant inline adapters. You should post the whole project in the Making Stuff Together section when you're done, I would like to see it.
Offline econeuler
Re: Hi Geekhack!
« Reply #8 on: Sun, 03 May 2020, 15:23:57 »
Yes I agree, functionality has its charm as well! Certainly, I will post when it's all done  :)
