Author Topic: QMK RGB Profile Maker/Script  (Read 1847 times)
Offline ZonFire99
« on: Sat, 25 April 2020, 00:34:09 »
I wasn't sure where to post this but I wanted to share it here. I made a script for making QMK RGB profiles. Specifically I have it setup for the DROP ALT. It's currently written for macOS but should be relatively simply to put into other languages and other boards. Once the script is done running you'll need to copy and paste the code into your rgb_matrix_kb.inc file. It will ask you a series of questions based on how you want your board to be styled; underglow, accent keys, complexity, etc. I'd be really interested in what you guys think :)
Code: [Select]
#!/bin/zsh
#### FUNCTIONS ####
PS3="Please make a selection:  "
function colorCheck {
if test "$ColorR:u" = "RED"
    then
      ColorR=FF;
      ColorG=00;
      ColorB=00;
  elif test "$ColorR:u" = "GREEN"
    then
      ColorR=00;
      ColorG=FF;
      ColorB=00;
  elif test "$ColorR:u" = "BLUE"
    then
      ColorR=00;
      ColorG=00;
      ColorB=FF;
  elif test "$ColorR:u" = "CYAN"
    then
      ColorR=00;
      ColorG=FF;
      ColorB=FF;
  elif test "$ColorR:u" = "AQUA"
    then
      ColorR=00;
      ColorG=FF;
      ColorB=FF;
  elif test "$ColorR:u" = "PURPLE"
    then
      ColorR=80;
      ColorG=00;
      ColorB=80;
  elif test "$ColorR:u" = "PURPLE2"
    then
      ColorR=52;
      ColorG=02;
      ColorB=FF;
  elif test "$ColorR:u" = "MAGENTA"
    then
      ColorR=FF;
      ColorG=00;
      ColorB=FF;
  elif test "$ColorR:u" = "FUSCHIA"
    then
      ColorR=FF;
      ColorG=00;
      ColorB=FF;
  elif test "$ColorR:u" = "YELLOW"
    then
      ColorR=FF;
      ColorG=FF;
      ColorB=00;
  elif test "$ColorR:u" = "PINK"
    then
      ColorR=FF;
      ColorG=69;
      ColorB=B4;
  elif test "$ColorR:u" = "ORANGE"
    then
      ColorR=FF;
      ColorG=A5;
      ColorB=00;
  elif test "$ColorR:u" = "BROWN"
    then
      ColorR=A5;
      ColorG=2A;
      ColorB=A5;
  elif test "$ColorR:u" = "CHOCOLATE"
    then
      ColorR=D2;
      ColorG=69;
      ColorB=1E;
  elif test "$ColorR:u" = "OFF"
    then
      ColorR=00;
      ColorG=00;
      ColorB=00;
  elif test "$ColorR:u" = "WHITE"
    then
      ColorR=FF;
      ColorG=FF;
      ColorB=FF;
  elif test "$ColorR:u" = "LASER"
    then
      ColorR=FF;
      ColorG=00;
      ColorB=69;
  fi
function wholeBoard {
#if test "$ColorR:u" = Y || test "$ColorR:u" = YES
    echo "What color would you like?"
    read ColorR ColorG ColorB
    if test -z "$ColorG"
        then
        colorCheck;
    fi
    for i in $(seq 0 66); do
        palette="$palette \t\trgb_matrix_set_color($i, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    done
    echo "Different underglow color?"
    select opt in Yes No; do
        case $opt in
            Yes)
                echo "What color should it be?"
                    then
                        colorCheck;
                fi
                for i in $(seq 67 104); do
                done
                while true; do
                    echo " I recommend a file if there is something that script hasn't covered with your wants/needs."
                    read "?Clipboard or File? [c/f] " cf
                    case $cf in
                        [Cc]* ) echo "$beginning $(echo $palette | sort -V)\n $end" | pbcopy; echo "Enjoy!\nGoodbye.\n"; exit;;
                        [Ff]* ) echo "$beginning $(echo $palette | sort -V)\n $end" > $profile\_rgb\_matrix\.txt; echo "Enjoy!\nGoodbye.\n"; exit;;
                        * ) echo "Please answer clipboard or file.";;
                    esac
                done
            No)
                done
                while true; do
                    case $cf in
                    esac
                done
        esac
    done
function alternatingColors {
    echo "What is the first color?"
        then
            colorCheck;
    fi
    for i in $(seq 0 2 104); do
    done
    echo "What is the second color?"
        then
            colorCheck;
    fi
    for i in $(seq 1 2 104); do
    done
        while true; do
        case $cf in
        esac
    done
function rowsColors {
    echo "What color is the first row?"
        then
            colorCheck;
    fi
    #0 14, 86 100
    for i in $(seq 0 14); do #row 1
    done
    for i in $(seq 86  100); do
    done
    echo "What color is the second row?"
        then
            colorCheck;
    fi
    #15 29, 85, 101
    for i in $(seq 15 29); do #row 2
    done
    palette="$palette \t\trgb_matrix_set_color(85, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    palette="$palette \t\trgb_matrix_set_color(101, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    echo "What color is the third row?"
        then
            colorCheck;
    fi
    #30 43, 84, 102
    for i in $(seq 30 43); do #row 3
    done
    palette="$palette \t\trgb_matrix_set_color(84, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    palette="$palette \t\trgb_matrix_set_color(102, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    echo "What color is the fourth row?"
        then
            colorCheck;
    fi
    #44 57, 83, 103
    for i in $(seq 44 57); do # row 4
    done
    palette="$palette \t\trgb_matrix_set_color(83, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    palette="$palette \t\trgb_matrix_set_color(103, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    echo "What color is the fifth row?"
        then
            colorCheck;
    fi
    #58 82, 104
    for i in $(seq 58 82); do #row 5
    done
    palette="$palette \t\trgb_matrix_set_color(104, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    while true; do
        case $cf in
        esac
    done
function escColor {
    echo "What color would you like the ESC key? (NOTE: This will be your accent color)  "
        then
            colorCheck;
    fi
function accentKeys {
    echo "Would you like more accent keys?"
    select opt3 in "Yes (ESC, Enter, Space, Arrows)" "No (ESC, Arrows)"; do
        case $opt3 in
            "Yes (ESC, Enter, Space, Arrows)")
                #more accent keys (esc, enter, space, arrows)
                #0, 42, 56, 61, 64 66
                moreAccentColors="true";
                palette="$palette \t\trgb_matrix_set_color(0, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(42, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(56, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(61, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                for i in $(seq 64 66); do #
                done;
                #if more then outer is 1 15, 28 30, 43 44, 55, 57 60, 62, 63'
                return;
            "No (ESC, Arrows)")
                #less accent keys (esc, arrows)
                #0, 56, 64 66
                moreAccentColors="false";
                done;
                #if less then outer 1 15, 28 30,42, 43 44, 55, 57 60, 61, 62, 63
                return;
                echo "Invalid option $REPLY";
                echo "Please make a selection:  \n1) Yes \n2) No";
        esac
    done
function innerColor {
    echo "What color do you want the character keys? (Inner rows 1-3, not \|, Enter, Shift, or up arrow.) "
        then
            colorCheck;
    fi
    #inner keys
    #16 27
    #30 41
    #45 54
    for i in $(seq 16 27); do #inner row 2, qwer...
    done
    for i in $(seq 31 41); do #inner row 3, asdf...
    done
    for i in $(seq 45 54); do #inner row 4, zxcv...
    done
function outerKeys {
    echo "What color do you want the outer keys? "
        then
            colorCheck;
    fi
    if test "$moreAccentColors" = true;
        then
            #Outer keys (more)
            #1 15, 28 30, 43 44, 55, 57 60, 62, 63
            for i in $(seq 1 15); do #
            done
                palette="$palette \t\trgb_matrix_set_color(28, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);/// \\\| Key \n";
                palette="$palette \t\trgb_matrix_set_color(29, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(30, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(43, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(44, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
                palette="$palette \t\trgb_matrix_set_color(55, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
            for i in $(seq 57 60); do #
            done
            palette="$palette \t\trgb_matrix_set_color(62, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
            palette="$palette \t\trgb_matrix_set_color(63, 0x$ColorR:u, 0x$ColorG:u ,0x$ColorB:u);\n";
    elif test "$moreAccentColors" = false;
        then
            #Outer keys (less)
            #1 15, 28 30, 43, 44, 55, 57 63
            done
            for i in $(seq 28 30); do #
            done
            for i in $(seq 57 63); do #
            done
    fi
function alternatingUnderglowColors {
        then
            colorCheck;
    fi
    for i in $(seq 67 2 104); do
    done
        then
            colorCheck;
    fi
    for i in $(seq 68 2 104); do
    done
    while true; do
        case $cf in
        esac
    done
function UnderglowSections {
    echo "What is the bottom color?"
        then
            colorCheck;
    fi
    #bottom
    #67 81
    for i in $(seq 67 81); do #
    done
    echo "What is the left side color?"
        then
            colorCheck;
    fi
    #left
    # 101 104
    for i in $(seq 101 104); do #
    done
    echo "What is the top color?"
        then
            colorCheck;
    fi
    #top
    # 86 100
    for i in $(seq 86 100); do #
    done
    echo "What is the right side color?"
        then
            colorCheck;
    fi
    #right
    # 82 85
    for i in $(seq 82 85); do #
    done
    while true; do
        case $cf in
        esac
    done
function UnderglowColors {
        echo "Underglow colors?"
            select opt4 in All Sections Alternating; do
                case $opt4 in
                    All)
                            then
                                colorCheck;
                        fi
                        done
                        while true; do
                            case $cf in
                            esac
                        done
                    Sections)
                        UnderglowSections
                        while true; do
                            case $cf in
                                [Cc]* ) echo "$beginning $(echo $palette | sort -V)\n $end" | pbcopy; echo Enjoy!; echo ; echo "Goodbye."; exit;;
                                [Ff]* ) echo "$beginning $(echo $palette | sort -V)\n $end" > $profile\_rgb\_matrix\.txt; echo Enjoy!; echo ; echo "Goodbye."; exit;;
                            esac
                        done
                    Alternating)
                        while true; do
                            case $cf in
                            esac
                        done
                            echo "Please make a selection:  \n1) All \n2) Sections \n3) Alternating"
            esac
        done
#profile name, includes workaround for 'case' not knowing full RegEx
while true; do
    read "?What is the name of your profile? (Accepted characters: [a-zA-Z0-9_]) " profile
    beginning="RGB_MATRIX_EFFECT(RGB_CUSTOM_$profile:u)///MOVE THIS LINE TO YOUR IMPORTS OR INC LINE. USUALLY IN THE FIRST 10 LINES\n
static bool RGB_CUSTOM_$profile:u(effect_params_t* params) {
    RGB_MATRIX_USE_LIMITS(led_min, led_max);
        for (uint8_t i = led_min; i < led_max; i++) {"
    end="\t}
    return led_max < DRIVER_LED_TOTAL;
    if [[ $profile =~ [^0-9a-zA-Z_\s] ]]
        then
            GBU=B
    elif [[ $profile =~ [0-9a-zA-Z_] ]]
        then
            GBU=G
    fi
    case $GBU in
        G ) echo "OK, \"$profile\" it is then. "; break;;
        B ) echo "Nah uh uh. You didn't say the magic word. Try again.";;
    esac
done
echo "You may use HEX color values [00 ff 00] or your color options are:\n\nRED\tGREEN\tBLUE\tCYAN\nAQUA\tPURPLE\tPURPLE2\tMAGENTA\nFUSCHIA\tYELLOW\tPINK\tORANGE\nBROWN\tCHOCOLATE\tLASER\nWHITE\tOFF"
echo "Would you like something Simple or Complex? "
select opt in Simple Complex Quit; do
    case $opt in
        Simple)
            select opt2 in Rows Alternating "Whole board" back; do
                case $opt2 in
                    Rows)
                        rowsColors
                    Alternating)
                        alternatingColors;
                    "Whole board")
                        wholeBoard
                    back)
                        echo "Would you like something Simple or Complex?\n 1) Simple \n 2) Complex \n3) Quit"
                        break;;
                        echo "Please make a selection:  \n1) Simple \n2) Complex \n3) Quit"
                esac
            done
        Complex)
            escColor
            accentKeys
            innerColor
            outerKeys
            UnderglowColors #must be last.
        Quit)
            exit
    esac
done
