Author Topic: Help with 60% keyboard  (Read 1474 times)
Offline jgnav
« on: Sat, 25 April 2020, 06:26:50 »
Hi! I'm new this world of custom keyboard. I want to start with my first project a cheap 60% keyboard.
What do you think about this stuff?
https://es.aliexpress.com/item/32799437588.html?spm=a2g0o.cart.0.0.19e93c005vetQD&mp=1
https://es.aliexpress.com/item/32909665228.html?spm=a2g0o.cart.0.0.4e1f3c00yjhgDR&mp=1
Can you recommend the other stuff?
I've a lot of black MX cherry form old keyboard, no RGB and I live in Europe so I can't buy in USA.
« Last Edit: Sat, 25 April 2020, 06:59:20 by jgnav »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Help with 60% keyboard
« Reply #1 on: Sat, 25 April 2020, 07:01:54 »
Those will do the job just fine for your first build. I would suggest trying to find a PCB with more basic key placements as it's gonna be tough to use one with so many layout possibilities for your first build. Although I do get that may be the only 60% PCB available to you right now. If that is the case & you have to go with that PCB, use the keycaps to ensure you get the switches in the proper placment for the layout you want.
