Author Topic: Hallo!  (Read 2133 times)
Offline RabbitTone
Hallo!
« on: Sun, 26 April 2020, 11:49:29 »
I'm a CS Major and was looking to upgrade my current logitech keyboard, but I wasn't satisfied with a lot of the one-dimensional brands of mech boards like Razor.
That's until I was recently introduced to DIY Mech Keyboards surfing trough Youtube and r/mechanicalkeyboards. Making and customizing my own board drew me instantly.
I'm actually working on a project to build a keyboard as a gift to my friend for his birthday and I could really use some advice on what I have in mind.
It's supposed to be based on the Ducky One 2 Mini Horizon. Parts are as follows:
Switches- https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1644
Plate- https://www.aliexpress.com/item/32699111693.html?spm=2114.12010612.8148356.3.77157df4KArft1
Stabilizers- https://kbdfans.com/collections/plate/products/transparent-black-steel-plate-satellite-shaft-customization-mechanical-keyboard-plate-stab?variant=538550140941
Key caps- https://www.aliexpress.com/item/4000194630028.html?spm=a2g0o.productlist.0.0.402f12a9zAN5J7&algo_pvid=6257c352-951e-4672-b6c5-1f8c9a52dfff&algo_expid=6257c352-951e-4672-b6c5-1f8c9a52dfff-33&btsid=0ab6d67915874879011321651e0e71&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Case- https://kbdfans.com/collections/case/products/60-plastic-case?variant=28967500742704
PCB- https://kbdfans.com/products/dz60-60-pcb
Thanks in advance!
P.S. I'm also thinking of lubbing the keys and stabilizers so if anyone could point me to a good lube that'd be great
Offline Maledicted
Re: Hallo!
« Reply #1 on: Mon, 27 April 2020, 12:27:34 »
Thanks in advance!
Hi RabbitTone. Welcome to Geekhack.
I would suggest that you put everything you posted here in the Keyboards section of the forum instead. It gets more traffic, and responses, as far as suggestions. I don't think many people read, much less reply, here.
I don't do the whole LEGO thing, but I have ordered parts for one, and off the bat I have to bring up a few things:
1) Does your friend like linears in particular, and/or this is specifically for gaming?
2) For linears, people seem to prefer plates that result in deeper thock sounds. Such plates supposedly include brass, various plastics, and carbon fiber. Aluminum plates can ping more than other options (if that matters).
3) I'm no expert on stabilizers and plates yet, but the plate only mentions pcb-mounted stabilizers and the stabilizers you linked sound like they're plate-mount. It does appear that they may be incompatible, but others would know better than I.
I have heard from one veteran member of this site, DALExSNAIL, that he likes to use dielectric grease. It isn't electrically conductive and seems to do the job good enough for stabilizers. There seems to be some debate on lube for switches, even based on the type of switch. I would ask specifically about lube in relation to Gateron reds if you do make a post in the Keyboards section.
Mini USB is the goal for the PCB? And permanent soldering? If so  :thumb:
« Last Edit: Mon, 27 April 2020, 14:23:42 by Maledicted »
Offline RabbitTone
Re: Hallo!
« Reply #2 on: Tue, 28 April 2020, 13:28:34 »
It's more geared towards gaming. He streams games like Rocket League and R6S, so I felt some reds would suit him. I'm willing to take suggestions tho!
I'll make sure to take note of this, thanks! I've still got a lot to learn and I want to build one for myself in the near future so this is a great insight.
I'll look into this a lot more too. Maybe it wasn't such a good idea to source the parts from different vendors lol.
For sure I'll post this on the Keyboard section here but even this is of great help, I really appreciate it. I've never even done any soldering before, but I already bought a practice
kit online. Thank you
Offline Maledicted
Re: Hallo!
« Reply #3 on: Tue, 28 April 2020, 14:03:32 »
I'm not a linear guy myself. I still use Cherry MX reds with my gaming rig, although they wouldn't be my first choice. Kailh box reds feel much smoother, and the design is probably objectively better. Unfortunately, I don't know how those compare to any regular MX clones like Gaterons, although people generally like that brand for the price. I think the most praised linear switches are usually Novelkeys Creams, Tealios, and Alpacas (and even that can depend on whether or not you plan to lube them before assembly). I know, personally, I would really like something just a bit heavier than MX reds. They're so light that you can accidentally actuate them just resting your fingers on them.
I have plenty to learn myself, if I ever do. I'm a clicky guy, and I mostly use long-dead switch types and/or repurposed boards that I swapped box jades or navies into.
I do the same thing all of the time, be it car parts, computer parts, or whatever else. I think it is just universally true that you have to be 100% sure that you know what it is that you need. I posted in the Keyboards section myself about the parameters I used for a 65% board I plan to assemble if the apocalypse ever allows the parts to arrive.
Keyboards are probably the best modern practical place to learn soldering. The solder pads are huge and spaced out greatly compared to other modern electronics. If you follow a good tutorial and be patient until you get the hang of it, you'll do fine. You may even like it. Another option may be to go the hot swap route, then if your friend might want to try some different switches down the road, he can just swap another set in. The only thing is hot swap sockets have their own unique detriments as well. They'll never be as durable/reliable as directly soldering to the board. Just something to consider.
You're very welcome. I'm glad to help.
