Author Topic: Key puller  (Read 2993 times)
Offline MJmusicguy
Key puller
« on: Sun, 26 April 2020, 11:58:30 »
Recommended brand of key puller because of course my unicomp didnt come with one?
Offline Sup
Re: Key puller
« Reply #1 on: Sun, 26 April 2020, 12:55:38 »
Just any key-cap puller with wire will do the job don't get the one with the plastic claws they will scratch your key-caps
current
Coming soon
Offline rxc92
Re: Key puller
« Reply #2 on: Sun, 26 April 2020, 13:14:53 »
BS keycaps might need a little more force, so the plastic ring design would probably be better. They’re a few cents or bucks.
Offline mcRewind
Re: Key puller
« Reply #3 on: Sun, 26 April 2020, 16:34:21 »
I purchased this from Amazon and worked pretty nicely. Just tossed the keycaps that came with it lol
Offline Maledicted
Re: Key puller
« Reply #4 on: Mon, 27 April 2020, 12:03:24 »
I'll only add on to the plastic ring style ones in that they're sometimes better for oddly-shaped or long caps, like modifiers. The wire ones are better in every way for every other application. They can be kind of awkward for stabilized modifier keys.
Re: Key puller
« Reply #5 on: Mon, 27 April 2020, 13:03:37 »
You can make your own, of course.
The copper one is my favorite, I used the center wire from an old cable TV cable. (The "handle" is Hot Glue, in case you were about to ask.)
- D Trump 2026-10-24
Offline Maledicted
Re: Key puller
« Reply #6 on: Mon, 27 April 2020, 13:07:29 »
You stripped coaxial cable, twisted it, and hot glued a handle? Nice idea. The uses of hot glue have no bounds.
Let me guess on the other one:
Coat hanger, with vinyl tube for the handle?
Re: Key puller
« Reply #7 on: Mon, 27 April 2020, 14:21:25 »
Ha Ha, not hardly. Did you mean paper clip? That style takes 2.
Offline Maledicted
Re: Key puller
« Reply #8 on: Mon, 27 April 2020, 14:25:52 »
Nice.  :thumb:
