Author Topic: Compact-1800 Split Spacebar?  (Read 2298 times)
Offline goingthisway
« on: Thu, 30 April 2020, 19:25:25 »
Like the title says, do you guys know what compact-1800 kits or pcbs support split spacebar layouts? I think this is my ideal layout but recently I've been really liking having a split spacebar. Can't really find anything on compact-1800 boards with split spacebar though. Also, I'm not interested in layouts such as the YMDK96. Thanks!
Offline equalunique
Re: Compact-1800 Split Spacebar?
« Reply #1 on: Fri, 01 May 2020, 11:44:31 »
Not enough!
Only one I know of: Leeku1800
It supports multiple split spacebar arrangements, although that's nothing you'd be able to tell if you just looked it up on Google Images - sadly it looks like practically no one used those options.
I have one PCB that I've never used because honestly there isn't enough info for me to really feel comfortale with it. There's a Deskthority forum post on how to program it with the weird Windows-only Jigon software it needs. Not really enthusiastic about dealing with that. QMK would be better, and this is all from way before the TKC1800 was offered.
« Last Edit: Sun, 03 May 2020, 12:20:01 by equalunique »
