Author Topic: HHKB warranty  (Read 3340 times)
Offline foxtrap614
  • Always rem
HHKB warranty
« on: Fri, 01 May 2020, 17:43:39 »
Is the two year warranty that HHKB provides really good. I really want to open up my board and lube the stabs but if the warranty is really good thinking of just waiting the two years. It will be tough though with the  loud stab rattle do not know if I can make it that long.
"I don't think -- " "Then you shouldn't talk."
-Alice In Wonderland
Offline CrazyAssMonkey
Re: HHKB warranty
« Reply #1 on: Fri, 01 May 2020, 17:47:20 »
Oh snap man wrong board for the question. You should probably post this question there. I think that is how it works.  :thumb:
Edit: I love how I said where but never gave the name of the board, its the  Keyboard board I believe.
Though if this is a sneaky interest check I am curious.
« Last Edit: Fri, 01 May 2020, 17:49:11 by CrazyAssMonkey »
Offline foxtrap614
  • Always rem
Re: HHKB warranty
« Reply #2 on: Fri, 01 May 2020, 17:57:32 »
Shoot sorry about that i will see if i can change the post location.
Offline nu_types
  • Formerly Iredeus
Re: HHKB warranty
« Reply #3 on: Fri, 01 May 2020, 18:01:26 »
A mod already moved it :). As for the warranty, they won't do anything for rattly stabs. Lubing an hhkb is super easy though, here's a guide:
Offline foxtrap614
  • Always rem
Re: HHKB warranty
« Reply #4 on: Fri, 01 May 2020, 18:09:14 »
Nice, thanks for the guide.  :thumb:
Re: HHKB warranty
« Reply #5 on: Fri, 01 May 2020, 18:10:11 »
What is the chance that it fails in a way that won't be blamed on "wear and tear"?  Personally I think slim so once I'm happy anything works I'll void the warranty without hesitation.
That is assuming the warranty is even valid in the first place as most are only valid in the country of sale, which I'm guessing doesn't apply.
Offline foxtrap614
  • Always rem
Re: HHKB warranty
« Reply #6 on: Fri, 01 May 2020, 21:19:31 »
I agree. I just have not had any warranties that honored their coverage. They have always found a way to not cover the issue or you have to go through alot of shipping and telephone trouble shooting just to get coverage. I just wanted to check in the community to see if anyone can vouch for the quality of their service. I have yet to find a person who would.
Offline Zacharius
Re: HHKB warranty
« Reply #7 on: Sat, 02 May 2020, 00:04:25 »
Fortune favors the bold. Lads, lube your stabs. While you’re in there you might as well lube the rails as well.
