Author Topic: 1UP 60% Question  (Read 2172 times)
Offline spaceandy
1UP 60% Question
« on: Fri, 01 May 2020, 20:50:44 »
Hello GH,
I recently purchased my first premade PCB's from 1UPKeyboards and ended up getting a RGB underglow 60% and a JD40 and am eagerly awaiting the plague gods to free new york from their grasp.
My question is what are the 6 pins to the right of the spacebar switch socket for?
I originally wanted to make a gross mutilation involving a 4 key macropad and a rotary dial encoder in a 3 port USB Hub hidden within the case (i know i know) but if these are for IO that would certainly add to my purchase list.
Shorthanded,
spaceandy
Re: 1UP 60% Question
« Reply #1 on: Fri, 01 May 2020, 21:01:59 »
Those holes are probably an ISP header, so you can flash a bootloader to the board.  All being well you wont need to do that but the 3 pins in the header that are IO may also be connected to the switch matrix - you would need to check which pins are used in the firmware against the datasheet for the controller chip to find out.
Offline spaceandy
« Reply #2 on: Fri, 01 May 2020, 21:07:19 »
Word! Thanks for the homework, I'll be hopping to it. anything to prevent me from doing internal cable management is a big plus
« Reply #3 on: Sat, 02 May 2020, 04:56:40 »
You can also look for pins used as indicator LEDs - they may not be neatly grouped together but if you don't need the LED they're free pins.
Offline spaceandy
« Reply #4 on: Sat, 02 May 2020, 10:14:08 »
I looked into it further and found out they're actually breakout power points! I'm sure somewhere in the forum there was bound to be some information somewhere but i had no idea how to search for it.
I still need to research the controller and haven't got any good intel on if there are any available pins on it, but i'm hopeful.
Blessings
