Author Topic: Which keycaps are you using with Blue/Ultramarine/Navy keyboard case?  (Read 27127 times)
Offline Fklr
Hi to you all guys,
Recently I pre-order a Mekanisk Klippe TR4 Ultramarine but I'm very indecisive which keycaps to use in it.
I know it is a taste thing but I really would like to see some of your blue keyboards and your opinion on this renders below.
Thanks in advance and wish you all the best.
GMK Minimal
241483-0
GMK Classic Blue Base Kit 1
241487-1
GMK Classic Blue Base Kit 2
241485-2
GMK Masterpiece
241489-3
GMK Deep Navy (try not to care too much on the cutted layout)
241491-4
« Last Edit: Sun, 03 May 2020, 20:15:38 by Fklr »
Offline zslane
SA Dasher:
241556-0
GMK Nautilus:
241558-1
Offline Fklr
SA Dasher:
GMK Nautilus:
I like the nautilus but the Dasher looks damn good zslane, with the mouse combination and all. What keyboard case is that?
Today I pre-order the gmk deep navy so I'm aming to something like this but 60%, not 65%.
241564-0
Offline biothermal
  • Art
If you can deal without traditional legends, all of the pictures I've seen of GMK dots on a blue board have looked quite good.
Offline Fklr
Hum I like it but I not sure if I could use it on daily basis...
What do you think biothermal?
GMK Dots
241568-0
Offline Rob27shred
  • Insane in the Membrane! 👻
You don't have to have blue caps to compliment a blue case IMHO. On my night blue (I believe that was the color name) Noxary T60 I've been rocking GMK Oblivion V2 Git base with Hagoromo alphas & really like how they go together.
241570-0
Then to further my point I ended up throwing GMK Olive on to my red e6.5 & really like how that looks together even though it's a counterintuitive combo.
241572-1
Of course looks are very subjective & preferences will vary from person to person, but don't be afraid to experiment with color combos! Anyways, I saw you got in the GMK Deep Navy GB so you'll be covered by that. I think it should match really nice with Leandre's Ultramarine color!
Offline biothermal
  • Art
GMK Dots
Hey I like it. Then again I like minimalism all around. As Rob said above, you definitely aren't constrained to matching the board to the color of the keycaps, some contrasting sets would most likely look great as well.
Offline Fklr
That night blue case is insane! Blue is my partner in crime.
I understand your point. In the end of the day its all about preference but there are some keyboards, like yours, that are breath taking.
Can you share the other components of your builds?
Thanks for your time showing both of your keyboards.
Offline Fklr
GMK Dots
You are totally rigth. The reason I created this post was exactly this, to get other people perspective and to be able to look at it from another perspective.
If the stars align, I hope to be able to show you my final result in Q1 2021.
Offline zslane
It's a Norbauer NovaTouch aluminum case.
Offline HungerMechanic
Re: Which keycaps are you using with Blue/Ultramarine/Navy keyboard case?
« Reply #10 on: Tue, 05 May 2020, 11:49:19 »
Solarized Dark also looks good on blue boards. A Google search will show it.
Offline Fklr
« Reply #11 on: Tue, 05 May 2020, 12:49:17 »
I know that one. That's the keycap set that mekanisk use a lot in there photos/renders. :thumb:
Offline kotlkahn
« Reply #12 on: Wed, 10 June 2020, 11:53:36 »
Hey!!
I bought the Klippe T 4 Ultramarine as well, and I was under the same dilemma.
I got two keycap sets to go with it :
1) Ducky Joker - For gaming (It's great for the 50$ price and I won't mind ruining them by mashing the keys in a year or two)
2) GMK Dolch 2 - The groupbuy is live right now, and it's 100$ (cheap for a GMK set). Black/Grey/White go well with any base color imo. You could also opt for the "mist" version of Dolch 2, as it has blue legends.
I'm new to this hobby so I don't comment much, but I'm quite proud of the theme I'm going for with my PC setup so rest assured that I put a lot of thought into this :D
PS:This is gonna be my first build and I already spent 450+ euros on it XD
Cheers!
Offline Fklr
« Reply #13 on: Wed, 10 June 2020, 13:37:36 »
Hi kotlkahn,
I'm new at this hobby as well but I already entered in 2 diffrent group buys. GMK Deep Navy early may and GMK Nord Today!
This is an awesome hobby but a really expensive one. I already spend a huge amount of money.
What other parts did you get to your build beyond the keycaps and case? Did you get the ultramarine durock x mekanisk stabs?
Cheers!
Offline wholypantalones
  • text and icon mods plz.
« Reply #14 on: Wed, 10 June 2020, 14:39:31 »
Oblivion Monochrome - Lin Montage
Offline kotlkahn
« Reply #15 on: Thu, 11 June 2020, 11:39:20 »
Cheers!
I did buy durock stabs but not the ultramarine ones sadly. I got the transparent ones (with gold wires).
For switches, I got novelkeys cream switches. Gonna lube them with krytox 205g0.
At the same time, I started modding my current keyboard (Anne Pro 2). I got a thick aluminium case for it, along with aliaqz 70g switches. I'll install hot swap sockets (millmax ones) on the board and it will serve as my experiment board (to try different switches). It will also help me learn the skills I need to build a keyboard well.
PS : Love your keycap choices.
Cheers!
Offline KeycapsVN
« Reply #16 on: Tue, 16 June 2020, 09:00:34 »
I think this spacebar would make the Navy keyboard case more eye catching.
Offline Fklr
« Reply #17 on: Tue, 16 June 2020, 09:08:31 »
Both look amazing but that blue fade is really nice!
Offline kotlkahn
« Reply #18 on: Tue, 27 April 2021, 10:23:28 »
Hey there again!
Just in case you're still looking for matching keycaps, the GMK Seafarer set looks perfect to me for the Klippe Ultramarine!
Cheers!
Offline Fklr
« Reply #19 on: Mon, 03 May 2021, 01:42:38 »
It looks very good indeed but I joined many gmk gb (7) since then that I have to skip this one  ^-^
Offline Fklr
« Reply #20 on: Mon, 03 May 2021, 01:50:05 »
Im aiming towards this image
I joined gmk minimal, when i receive it i will post some pics  :thumb:
« Last Edit: Mon, 03 May 2021, 01:52:23 by Fklr »
Offline kylejim
« Reply #21 on: Mon, 03 May 2021, 14:25:39 »
Buy Mekanisk Type X Ultramarine Aluminum Keyboard Case in Singapore
https://www.computerizedsewingmachines.com/
