Author Topic: Das II keyboard  (Read 2557 times)
Offline elbowglue
Das II keyboard
« on: Thu, 01 July 2010, 18:34:16 »
http://cgi.ebay.com/Das-Keyboard-Blank-Computer-Keyboard-/160449992955?cmd=ViewItem&pt=PCA_Mice_Trackballs&hash=item255b9098fb#ht_2151wt_930
*** EDIT this appears to be a Das I which is a keytronic keyboard, sorry for the confusion ***
(It's a rebranded g80-3000 with blue cherries and blank keys.  PCB mounted.  I would probably pay max of $66 shipped for this, as the g80-3000LSCRC-2 was $67 shipped when it was available for purchase.)
The seller has no idea what he is doing too:
Most keyboards use a standard 55 grams of force required to register every key, Das Keyboard has 5 different levels of force. The keys are divided into groups and their feedback springs are weighted differently; from 35 grams to 80 grams, which correspond to the strength of the finger that touches the keys. The result is more comfort for your hands.
« Last Edit: Fri, 02 July 2010, 11:59:42 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline TexasFlood
Das II keyboard
« Reply #1 on: Thu, 01 July 2010, 19:09:39 »
Quote from: elbowglue;198474
Might want to be careful, I think that the pictures in the ebay ad (below) are of an original DAS, not the DAS II.  Might be the wrong pictures but be careful.
Offline aegrotatio
Das II keyboard
« Reply #2 on: Thu, 01 July 2010, 21:54:07 »
Quote from: TexasFlood;198482
Ut-oh, that's the original rubber dome Key Tronic keyboard with custom black color and a DAS label slapped on it.  If you're looking for clicky snobbishness, this isn't that keyboard.
Save your money and get a $6 Key Tronic ivory and spray-paint it black.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline didjamatic
Das II keyboard
« Reply #3 on: Thu, 01 July 2010, 22:01:15 »
From auction description: "High-quality membrane switch technology"
Offline TexasFlood
Das II keyboard
« Reply #4 on: Thu, 01 July 2010, 22:17:10 »
Quote from: didjamatic;198531
So, it's "high-quality", I better go get it huh? :wink:
Or...
Buy 9 of these same keyboards in white for the same cost as the starting bid of this and paint them black, or purple or whatever as aegrotatio suggested, :smile:
Or maybe do neither.  I am seriously considering some of the pacific geek $4.99 white key tronic keyboards through, for RIT dye experiments if nothing else.
« Last Edit: Thu, 01 July 2010, 22:22:01 by TexasFlood »
Offline TexasFlood
Das II keyboard
« Reply #5 on: Thu, 01 July 2010, 23:06:47 »
If I take that pacific geek $4.99 keyboard and strip the white out of it, looks kinda familiar?
Offline aegrotatio
Das II keyboard
« Reply #6 on: Thu, 01 July 2010, 23:10:29 »
Honestly, though, for "membrane" rubber dome keyboards, Key Tronics are still possibly the best bang-for-the-buck keyboard.  I'm saying you can get the same thing for way much less without the blank key gimmick.
Offline TexasFlood
Das II keyboard
« Reply #7 on: Fri, 02 July 2010, 08:10:15 »
Quote from: aegrotatio;198559
Which is exactly why I'm considering picking up some of those white Key Tronic boards to use in some dye experiments.  Could be a lot of fun with the kids for example maybe make a purple board for my daughter, :wink:.  Cheap enough to trash if it goes wrong and decently usable if it works.
Offline Laggy-gaga
Das II keyboard
« Reply #8 on: Fri, 02 July 2010, 08:18:47 »
This is DAS I, DAS II  is OEM by Cherry, se num 3485
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
