Author Topic: [IC] CW 88/60 (PROJECT SCRAPPED AND UPDATED)  (Read 77221 times)
Offline bsanto
Re: [IC] ACW 88% + 60% - Dyed Polycarb (PROTOTYPE UPDATE)
« Reply #100 on: Mon, 21 September 2020, 02:55:59 »
that smoked TKL tho. btw is the case seamless? what PCB do you use? and does fixed cable mean that it'll always dangle from the keyboard?
Offline zedbraxmen
  • Sheesh
« Reply #101 on: Sun, 27 September 2020, 21:01:37 »
The fixed cable does mean that it'll always dangle (like a short tail), but i don't think the length of the fixed cable is long enough to be a bother, but might be awkward if it were to be put in a case or something.
HHKB Kei | Constellation
Offline dibstern
Re: [IC] ACW 88% & 60% (Polycarbonate) PROTOTYPES DELIVERED
« Reply #102 on: Thu, 15 October 2020, 08:22:08 »
A few quick pictures before prototypes are dropped off for dye and surface treatment. Expect quite a few updates, pictures and an official groupbuy thread here shortly.
Those interested can follow us on Discord for more direct updates: https://discord.gg/cGQhbhm
Am I weird for really liking this pre-dye colour?
Edit: Oh wait it's not hot swap, never mind
the board not supporting hotswap shouldn't be a deal breaker :(
It was a dealbreaker for me at the time, but that was before I realised that Mill-max sockets are a decent option :)
Offline Arithmetics
« Reply #103 on: Thu, 15 October 2020, 10:54:47 »
love when someone say's they'll be out unless a certain feature is supported. meanwhile there's like 1000 entries for 100 spots on these GBs...
Offline nikotypo
« Reply #104 on: Wed, 19 May 2021, 03:35:25 »
Love this!
Is is it too late to get in the GB for the Poly TKL? The website seems to be down and I couldn't find any info on the Discord.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #105 on: Wed, 19 May 2021, 04:16:36 »
Love this!
Polycarb version will run after Aluminum gb is completed. Nothing has been started yet.
« Reply #106 on: Sat, 22 May 2021, 11:07:27 »
looks awesome!!
Offline cruelworld
  • Formerly 'acruelwrld'
    • cruel world
Re: [IC] CW 88/60 (PROJECT SCRAPPED AND UPDATED)
« Reply #107 on: Mon, 15 November 2021, 16:08:02 »
whaddup everybody
this project has long since been scrapped, redesigned and is now progressing into a groupbuy - will revisit colored poly in the future:
In the mean time follow the new thread: https://geekhack.org/index.php?topic=115297.msg3094417;boardseen#new
or come hang out with us on discord: https://discord.gg/cGQhbhm
