Author Topic: [IC] CW 88/60 (PROJECT SCRAPPED AND UPDATED)  (Read 77220 times)
Offline cruelworld
  • Formerly 'acruelwrld'
    • cruel world
« on: Thu, 07 May 2020, 15:41:27 »
whaddup everybody
this project has long since been scrapped, redesigned and is now progressing into a groupbuy - will revisit colored poly in the future:
In the mean time follow the new thread: https://geekhack.org/index.php?topic=115297.msg3094417;boardseen#new
or come hang out with us on discord: https://discord.gg/cGQhbhm
Special thanks to the following for their expert advice:
Cable maker Hexaphant of https://coaxius.com
PCB Fabricator Hineybush of hineybush.com
Renderer Kingk22 of https://kingk22.xyz
CW60
HHKB 60% Layout
Available in 'smoked' grey dyed polycarbonate and white untreated polycarbonate
Optional aluminum top enclosure
5.5˚ typing angle
'Koala' side profile
Proprietary plate (polycarbonate, stainless steel, full/half plate options)
TPU printed gaskets (60A)
Transparent silicone silencing mat
Polished stainless steel internal weight
CW88
88% WKL TKL ‘F13’ top row
Fixed internal cable with LEMO connector and yank proof mounting assembly
5.5˚ typing angle
Proprietary plate available in polycarbonate, stainless steel, full/half plate options
« Last Edit: Mon, 15 November 2021, 16:08:44 by cruelworld »
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC](nice things)CRUEL WORLD ® CW88 + CW60
« Reply #1 on: Thu, 07 May 2020, 16:02:11 »
Lookin good, boss :cool:
Offline mta
« Reply #2 on: Thu, 07 May 2020, 16:14:28 »
Really like the smoked gray look
Offline Fredington
    • Instagram
« Reply #3 on: Thu, 07 May 2020, 16:23:23 »
Interested in the 60.
Offline pchoi
« Reply #4 on: Thu, 07 May 2020, 16:35:23 »
That 60 looks niceeee. $375 on the other hand... ouch
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
« Reply #5 on: Thu, 07 May 2020, 16:47:34 »
Never really got into the HHKB layout, love that smoked TKL though.
« Reply #6 on: Thu, 07 May 2020, 17:07:57 »
Looks good. Looking forward to seeing how this turns out once you've found a manufacturer; I think that's gonna be the crucial part.
I wish the not happy/not sad smiley were somewhere on the board though. Gives off strong rave vibes.
Offline Jaltr
« Reply #7 on: Thu, 07 May 2020, 17:28:40 »
Yes, please.
Offline Vyndem
« Reply #8 on: Thu, 07 May 2020, 17:36:07 »
Will there be a hotswap pcb option?
Offline yhs
« Reply #9 on: Thu, 07 May 2020, 17:37:41 »
I’m in.
Offline cruelworld
    • cruel world
« Reply #10 on: Thu, 07 May 2020, 17:48:33 »
A fabricator has been sourced for all components, my most crucial concern is ensuring a consistent dye job for the enclosure. One thing I forgot to mention is that I plan on making my STEP file for the gaskets open source following the groupbuy, while 60A is typical for gaskets I want to encourage people to print them in different TPU hardness types or even Delrin/Pom plastic.
The logo will be present though it's not featured in renders; as of now it's placed as a plate engraving on the right-side HHKB blocker and above the arrow cluster on the TKL. I've also considered doing a white enamel fill on both so that they're visible through the top enclosure but we'll explore that more when prototypes arrive.
Sorry, not really interested in doing hotswap.
« Reply #11 on: Thu, 07 May 2020, 17:58:22 »
:thumb: You've got your head in the right place. Best of luck, I'm looking forward to seeing the fruits.
Offline Owl
« Reply #12 on: Thu, 07 May 2020, 18:43:07 »
uh yes. Dyed PC looks SO good. I'll take one.
Offline ab042896
« Reply #13 on: Thu, 07 May 2020, 18:49:14 »
I love the look of dyed PC, I'm not a fan of the plain PC typically, but this might bring it to another level.
Do you have any angles featuring the silicone silencing mat? Is it an internal dampener or is it replacing bottom side bumpers?
Also F13  :thumb:
« Last Edit: Thu, 07 May 2020, 18:51:26 by ab042896 »
Offline cruelworld
    • cruel world
« Reply #14 on: Thu, 07 May 2020, 19:51:45 »
Also F13  :thumb:
Unfortunately it's kinda' difficult to show in renders but the first one will likely ship before the enclosure prototype, expect some pictures shortly. It's essentially a large mat of lasercut silicone that seats into the bottom of the case with a center cutout around the weight. I chose silicone as it's easy to cut, comes in a variety of different weights and is transparent so it remains fairly camouflaged inside of a transparent case. Of the material samples I've handled so far, I would compare it to what you'd find in a Silpat baking mat in terms of texture and pliability.
Offline despairsray
« Reply #15 on: Thu, 07 May 2020, 20:36:09 »
This looks amazing, very interested.
Is it just me or your discord link not working? it says it is invalid
Offline cruelworld
    • cruel world
« Reply #16 on: Thu, 07 May 2020, 20:40:51 »
Discord link fixed! Thanks for the heads up.
Offline ab042896
« Reply #17 on: Thu, 07 May 2020, 21:02:12 »
Also F13  :thumb:
Love it, the transparency of PC is a blessing and a curse, although I'm sure this'll pair nicely
Offline noorejji
« Reply #18 on: Thu, 07 May 2020, 21:58:51 »
I like the look of the TKL, but a bit too pricey for me. GL with IC!
Offline Vadurr
  • Valar Morghulis
« Reply #19 on: Thu, 07 May 2020, 23:20:04 »
This def looks promising.
Offline huey
« Reply #20 on: Fri, 08 May 2020, 03:56:11 »
Is it really necessary to go through your website(that serves no purpose other than branding) to fill out an IC form done using google docs. Just link your site, if people want to go to it then they will. If they don't, they won't.
Offline hottrout
  • I'd Hit Dat Key
« Reply #21 on: Fri, 08 May 2020, 04:06:52 »
Any ISO for the TKL?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline cmd
« Reply #22 on: Fri, 08 May 2020, 06:54:48 »
Looking forward to the 88  :p
Potential is v strong with this design. Agree with photekq. I think the logo should make it somewhere on the board.
Offline ab042896
« Reply #23 on: Fri, 08 May 2020, 07:50:30 »
My preference is always on the side of no obvious branding, however the proposal for plate engraving considering a semi-transparent case sounds like a nice middle ground for those who prefer such a thing.
Offline cruelworld
    • cruel world
« Reply #24 on: Fri, 08 May 2020, 14:54:41 »
ISO support included!
I'm a big fan of 'subtle enough' branding I guess I would call it and I love to play with typography and graphic design - have quite a few ideas I can't wait to show you guys in the near future.
Offline mrkantz
« Reply #25 on: Fri, 08 May 2020, 15:20:55 »
I normally hate branding on boards, but I want his board for the branding
Offline hottrout
  • I'd Hit Dat Key
« Reply #26 on: Fri, 08 May 2020, 18:31:39 »
OK now you have my attention.  Is both colours available in both boards?
Systems -
  Keyboards -
Offline cruelworld
    • cruel world
« Reply #27 on: Fri, 08 May 2020, 20:07:55 »
Both colors for both boards with an option to add a corresponding aluminum top (grey and silver) similar to what was offered in the Lynn Whale GB, another one of my favorite boards.
« Last Edit: Fri, 08 May 2020, 20:41:38 by acruelwrld »
Offline hottrout
  • I'd Hit Dat Key
« Reply #28 on: Sat, 09 May 2020, 03:23:53 »
Nice, the dark charcoal is really nice.
Systems -
  Keyboards -
Offline socalmitch
« Reply #29 on: Sat, 09 May 2020, 15:58:51 »
Really interested in that TKL!
I like the smile/frown logo more than "Cruelworld" on the weight but other than that boards look good!
« Last Edit: Sat, 09 May 2020, 16:05:13 by socalmitch »
Offline Lazy_Borzoi
« Reply #30 on: Sun, 10 May 2020, 19:13:32 »
Very nice. Looking forward to the TKL.
Offline leexy
« Reply #31 on: Sun, 10 May 2020, 19:18:14 »
cruel price tho
Offline prizeS
    • TastyKeys
« Reply #32 on: Sun, 10 May 2020, 22:14:45 »
cruel price tho
i see what you did there  :))
TKL be looking good! Should be in for a smoked PC 88 given that I don't buy too many TKL's before this runs.
i lub 65% and wkl tkl.
Offline 2truth
« Reply #33 on: Sun, 10 May 2020, 22:35:20 »
This looks clean! Great job. Been wanting a polycarb and I enjoy the hhkb layout, so if this is made I'm in for sure.
if the duo smiley gets printed where the hhkb branding is placed,
I'm buying two :-)
Offline cruelworld
    • cruel world
« Reply #34 on: Mon, 11 May 2020, 19:11:13 »
Hey there everyone! Just touching base, another rainy week in quarantine has proved more productive than initially planned and we're moving through our timeline faster than anticipated! With various prototype parts either in the post or being fabricated I hope to provide you with a more comprehensive update by the end of this week.
 This will likely include packaging samples, cable prototype samples from coaxius, gasket and silicone samples, some slight changes regarding changes in the final design, detailed information regarding groupbuy run times and deadlines as well as a website overhaul. Finally upon the arrival of our enclosures we'll wrap things up with an extensive prototype photoshoot before sending all four kits to two preselected and highly regarded build streamers for review as previously mentioned.
 For any questions feel free to drop me a line and I'll get back to you as soon as I can, otherwise be safe and have a great day!
« Last Edit: Mon, 11 May 2020, 19:13:06 by acruelwrld »
Offline yui46
« Reply #35 on: Mon, 11 May 2020, 21:17:23 »
Interesting, will be keeping track for sure.
Offline avtar
« Reply #36 on: Mon, 11 May 2020, 22:32:55 »
Branding on the plate sounds reasonable. If it's visible on the board then I'll pass.
Offline jani80k
  • In the hobby for a good time.
« Reply #37 on: Tue, 12 May 2020, 08:27:07 »
Offline segami
« Reply #38 on: Mon, 18 May 2020, 12:30:20 »
Submitted the IC forms for both. Praying the TKL will be alps compatible with either the provided pcb or hineys. And pls no FCFS🙏
Offline dlavelle94
« Reply #39 on: Mon, 18 May 2020, 13:12:06 »
A very nice board and design but the $550 - 600 is very off putting
Offline Nvr_Smile
« Reply #40 on: Mon, 18 May 2020, 18:18:44 »
This just might be the first 60 I try to get into. Super nice looking board. Excited to hear any new updates.
« Reply #41 on: Mon, 18 May 2020, 18:24:18 »
He said they'll be available in limited qty's :(
TGR Jane V2 | TGR Alice | TGR Police | TGR 910 RE (Polycarbonate) | OTD Mini | Matrix 2.0 OG Pink | Lin Dolinger RE (Polycarbonate) | Lin Dolphin |
Offline cruelworld
    • cruel world
Re: [IC](nt)CRUEL WORLD® CW88 + CW60
« Reply #42 on: Wed, 20 May 2020, 18:12:12 »
Hey everybody, just a few updates as we progress through to the end of the month. With prototypes in production, cable swatches being selected and website updates underway I’m pleased to announce everything is coming together rather quickly.
That said there have been a few slight changes for the better:
- Gasket construction has been changed from a 3D printed TPU to injection molded silicone. With future groupbuys planned and cross compatibility between boards I wanted to guarantee a more consistent gasket with a more streamlined production process. This gasket will be the same standardized 60A hardness as the original and will come in a transparent silicone to better obscure its view inside of our polycarbonate case. Buyers will still have access to the gaskets STL file via a QR coded customer card that will be shipped with the kit in the event that they want to experiment with different material types or hardnesses.
- The internal weight design has changed significantly and now features the logo rather than the original typeface, several engravings have been added to both the plate and inverse of the weight. In addition to design, weight finish will be changing from a high polish to a brushed finish after reviewing some sample materials.
- Cable wrap options for the included cable on the 88-key TKL will include either a black MDPC-X or a white MDPC-X per customers preference.
Expect more updates over the coming weeks and feel free to join my Discord for more details: https://discord.gg/c6X5x2
And finally, some exploded views to give you a better idea of how this thing goes together:
« Last Edit: Wed, 20 May 2020, 22:14:46 by acruelwrld »
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #43 on: Wed, 20 May 2020, 18:23:43 »
- The internal weight design has changed significantly and now features the logo rather than the original typeface, several engravings have been added to both the plate and inverse of the weight. In addition to design, weight finish will be changing from a high polish to a matte finish after reviewing some sample materials.
uncheck lineweights when you're exporting the pdf from fusion
Offline CrazyAssMonkey
« Reply #44 on: Wed, 20 May 2020, 18:24:18 »
Is it a custom pcb? Or can a standard one work?
Offline cruelworld
    • cruel world
« Reply #45 on: Wed, 20 May 2020, 18:39:10 »
Thanks! Unfortunately keeping costs low is difficult when factoring in multiple proprietary parts, a custom colored small batch dye process, injection molded gaskets, etc.
Thanks for this, fixing ASAP.
Thanks for your support and feel free to hit me up if you have any questions!
;( open buy, sorry. The latest reiteration of the H88 does in fact support alps, though the first round of this board won't. Following a second round I'd like to introduce alps support via a secondary groupbuy with different gasket/plate material options if there's enough interest.
The TKL will utilize the latest version of the H88 whereas I'm still trying to determine which 60% PCB will be shipped with the kit though it does feature support for the most common options.
« Last Edit: Wed, 20 May 2020, 18:41:08 by acruelwrld »
« Reply #46 on: Wed, 20 May 2020, 18:54:25 »
Oh snap alright
Thanks
Offline thestateofmay
« Reply #47 on: Wed, 20 May 2020, 22:09:34 »
Insta buy if available in more colors.
Offline cruelworld
    • cruel world
« Reply #48 on: Wed, 20 May 2020, 22:22:59 »
That’s the idea eventually! Once I can prove consistency in the dye process with this run I’d like to expand into other colors as well.
Out of curiosity, what colors would you like to see offered?
« Reply #49 on: Wed, 20 May 2020, 22:50:13 »
I don't have specifics in mind but I would love to see brighter colors like yellow, blue, or green. White would probably also be a safe bet.
