Author Topic: sticking topre dome  (Read 1685 times)
Offline _rubik
sticking topre dome
« on: Sat, 09 May 2020, 19:05:24 »
I've daily-ed my RF87u with BKE redux heavies for ~6 months now (and that translates to probably around 10 hours a day at my desk). I recently noticed that my backspace key is "sticking" (it takes some fraction of a second to pop back up after I release it).
I'll probably pull it apart tonight and swap the dome with a less used key to see if that fixes it. Has anyone run into anything similar before?
Offline Hyde
  • White Tofu Extraordinaire
Re: sticking topre dome
« Reply #1 on: Sat, 09 May 2020, 22:27:00 »
It did happen to one of my friend and he said he had to put lube on the middle part of the dome (where the electro-capacitive sensor is on the pcb) and that seems to fixed it.
However I'm not 100% sure if your issue is exactly the same as his.
Hopefully yours gets resolved when you open it up though.
