Author Topic: Is it Worth if I buy the new Alps keyboard  (Read 2833 times)
Offline jannie2020
« on: Sun, 10 May 2020, 00:22:52 »
Because I heard that the alps keyboard is quite not working well , It is old and not less than 20 years old
Plus i cant find Acer kb101-a anywhere
so i decide to buy new Apple Extended Keyboard II  (sealed factory) i saw on Ebay do u think it worth?
Offline mode
Re: Is it Worth if I buy the new Alps keyboard
« Reply #1 on: Sun, 10 May 2020, 02:53:24 »
If you like damped switches, and it comes with pine cream ALPS, then yes. Otherwise, you're probably better off looking out for an AEK1 with Salmon or Orange switches as they're much nicer.
Prepare to spend silly money if you want one of those NOS though. They do come up occasionally, they just go for a premium, this one isn't explicitly NOS, it superficially looks clean though, but it is super expensive: https://www.ebay.com/itm/Apple-Extended-Keyboard-Mac-SE-IIgs-ADB-Desktop-Bus-M0115-ORANGE-ALPS-RARE/324130171526?epid=1201794340&hash=item4b77a9ea86:g:ZSEAAOSwdIlejkgy
If you want to dip your toe in, it's pretty easy to get an M0116 in reasonable condition for under $100 I really like those little boards, if you can get used to the slightly weird layout they're really nice.
« Last Edit: Sun, 10 May 2020, 03:15:06 by mode »
Offline jannie2020
« Reply #2 on: Sun, 10 May 2020, 03:04:58 »
If you want to dip your toe in, it's pretty easy to get an M0116 in reasonable condition for under $100 I really like those little boards, if you can get used go the slightly weird layout they're really nice.
hey thank for suggestion  :thumb:
Offline antcrm
« Reply #3 on: Sun, 17 May 2020, 04:54:44 »
feel good,I want it
