Author Topic: Active USB cable from certain ebay seller?  (Read 1684 times)
Offline mnpikey
« on: Sun, 10 May 2020, 15:14:26 »
Hey everyone,
I tried searching but it seems like alot of older posts are no longer there? A long time ago I converted a Dolch PAC to USB using a RJ11 crimp connected to a USB cable recommended from a certain ebay seller. This is a while ago so I'm guessing they are gone but I'd like to find the cable if possible somewhere. It was an active USB cable but looked like a normal one with no extra inline boxes or anything. Just a raw connector at one end and USB A at the other end.
Re: Active USB cable from certain ebay seller?
« Reply #1 on: Sun, 10 May 2020, 15:24:23 »
Was it from Orihalcon perhaps?
« Last Edit: Sun, 10 May 2020, 15:27:16 by suicidal_orange »
Offline shawn o
« Reply #2 on: Sun, 10 May 2020, 15:42:23 »
Wasn't someone selling 10ft ID Innovations ones a long time ago?
