Author Topic: My first build. Suggestions  (Read 3201 times)
Offline mpamplona
« on: Mon, 11 May 2020, 10:46:44 »
Hi, i'm new here and want to build my first keyboard.
I need suggestions for a already made open-source project with these fullfillments:
- > 60%
- Plate in PCB material, to manufacture in same place as the mainboard (if the project have one). I don't know if this is a good idea, but i think this is cheap to manufacture and have great precision.
I'm a electronics enginner, and my idea is to use a open source project as starting point to a customized version.
Offline nevin
Re: My first build. Suggestions
« Reply #1 on: Mon, 11 May 2020, 11:20:00 »
yes, FR4 (pcb material) makes for good plates as well as being inexpensive.
take a look at keeb.io for examples of simple spaced/sandwich style boards (most are ergo, not standard boards)
- as far as manufacturers.... i don't have any experience or suggestions for you.
- you could do a layered acylic case if you want a little more than just two spaced FR4 plates (ponoko.com or similar)
some tools
Keyboard Layout Editor
SwillKB Plate & Case Builder
info
https://wiki.ai03.me/
https://github.com/ai03-2725
as well as the popular GH60
Offline Applet
« Reply #2 on: Mon, 11 May 2020, 11:29:50 »
I have made a project with a 60% tray-mount PCB with FR4-plate. Just recently ordered plates, they turned out great imo.
https://github.com/4pplet/waffling60
Gerbers for plate is not included in the release, but I can add them if needed. Project is designed in Altium 17, prototypes of PCB and plate ordered from JLCPCB.
« Last Edit: Mon, 11 May 2020, 12:06:15 by Applet »
Offline mpamplona
« Reply #3 on: Tue, 12 May 2020, 03:45:43 »
Hey! Your project is awesome, thank you.
Do you have any spare plates/pcb to sell ?
Offline Applet
« Reply #4 on: Tue, 12 May 2020, 10:26:33 »
Thanks! :D PM sent
