Author Topic: ask Alps fans about this thing  (Read 4305 times)
Offline jannie2020
« on: Tue, 12 May 2020, 04:03:35 »
Drakware ADB2USB
i just  bought this item can u tell me it work on my  Apple extended keyboard to my PC right
do i need to buy  or do Anything else  thanks!
« Last Edit: Tue, 12 May 2020, 05:26:00 by jannie2020 »
Offline Sup
Re: ask Alps fans about this thing
« Reply #1 on: Tue, 12 May 2020, 06:40:38 »
I used it on my AEK II works great also easy to rebind other keys with it. its basically plug and play. You don't need anything else.
current
Coming soon
Offline jannie2020
« Reply #2 on: Tue, 12 May 2020, 06:48:14 »
thankyou so much sir  :thumb:
Offline mode
« Reply #3 on: Sun, 17 May 2020, 07:26:55 »
Yup, I have one and use it with an M0116. I regret not going for hasu's converter though as they're better for customising, still happy with it as it's useful to have a clean easy to use adapter I can test boards with.
