Author Topic: [IC] Keykobo Tidal (Kitting and verifying vendors)  (Read 60220 times)
Offline Steak
Re: [IC] Tidal (IC form added)
« Reply #50 on: Mon, 18 May 2020, 08:42:59 »
The more I look at this I think I'd like the set a bit more if there was more contrast between the colors.
Offline //gainsborough
  • MATRIXの日常
« Reply #51 on: Mon, 18 May 2020, 22:41:30 »
I'm not sure how this is received but this could be an additional add-on kit for you mono boys/girls if Tidal is well received
Something to this extent.
My absolute man!!!!
Offline Current Keyboards
    • currentkeyboards.com
« Reply #52 on: Wed, 20 May 2020, 16:16:45 »
See for me, I really like the light gradient.
Offline thecyangiant
« Reply #53 on: Wed, 20 May 2020, 21:57:10 »
+1 I really really like the subtle gradient. It's calming and cool.
Sent from my SM-N950U using Tapatalk
Offline Mcnos
    • GMK Fuyu
« Reply #54 on: Thu, 21 May 2020, 02:35:40 »
A question that I forgot to add to the form.
Would the set being GMK prevent you from supporting this project?
Offline neutralstate
« Reply #55 on: Thu, 21 May 2020, 05:34:22 »
maybe we can consider jtk for this?
« Reply #56 on: Thu, 21 May 2020, 07:59:22 »
I'd enjoy it in GMK
Offline Xdoc6
« Reply #57 on: Thu, 21 May 2020, 10:47:59 »
Could we have the numpad fade to white? Angle from 0, 2, 6, +?
Offline SantiGo
« Reply #58 on: Thu, 21 May 2020, 15:00:14 »
Nice GL Man if you go with GMK i am in !!! :thumb: :thumb: :thumb:
Offline Mcnos
    • GMK Fuyu
« Reply #59 on: Thu, 21 May 2020, 15:11:58 »
I have plans to add a mono kit so this would throw a wrench in the mix.
Also I quite like the mono numpad.
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #60 on: Fri, 22 May 2020, 04:56:32 »
I can only assume this set will cost a lot if it is run through GMK, considering the complexity of unique colors in the base set.
Offline Mcnos
    • GMK Fuyu
« Reply #61 on: Fri, 22 May 2020, 05:03:21 »
A complexity of a set does not increase price of a set. The number of keys and kits would although.
Offline senryo
    • Thic Thock
« Reply #62 on: Fri, 22 May 2020, 05:07:59 »
I may not be as well versed as you in this area; but wouldn't getting more non-stock colors in a base set would inevitably increase the cost?
edit: I suck at editing the format.
Offline Mcnos
    • GMK Fuyu
« Reply #63 on: Fri, 22 May 2020, 05:27:02 »
No, custom colors do not affect pricing but they do affect MOQ.
Offline Mcnos
    • GMK Fuyu
« Reply #64 on: Fri, 22 May 2020, 21:40:26 »
I went ahead and tried out to see how KAT would look like on the Pneuma by Stef
Let me know of your thoughts
Offline Zeelobby
« Reply #65 on: Fri, 22 May 2020, 21:44:27 »
Love gradient sets in KAT. Would be tempted to see KAM too. But I think KAT is more popular.
Sent from my Pixel 3 XL using Tapatalk
Offline peripherry
« Reply #66 on: Sat, 23 May 2020, 06:50:48 »
Wow, the KAT render though- so pretty! I love the smoothness of the color scheme.
Offline Mcnos
    • GMK Fuyu
« Reply #67 on: Sat, 23 May 2020, 07:39:44 »
I wouldn't put too much of the eggs in the basket yet, I'm more of less checking with the vendor on something. That will be the decider on what profile this will run in. I believe either choice will be pretty amazing in any case.
Offline oldcat
  • 65% is Life
« Reply #68 on: Sat, 23 May 2020, 14:05:09 »
Cherry.....pretty please....
Offline Mcnos
    • GMK Fuyu
« Reply #69 on: Sat, 23 May 2020, 14:23:13 »
Sure
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #70 on: Sat, 23 May 2020, 16:16:24 »
Love this in Cherry. I'd be interested in any Cherry profile (GMK for ABS, and Infinikey most likely for PBT).
KAM/KAT would see me skip this set, unfortunately. I personally am not a fan of the glossiness; I have KAM Starry Night, and barely lasted a day with it on my board (though that particular set haunts me for a number of reasons, the texture was the deciding factor).
If PBT is still desired in a non-Cherry profile, XDA may be a good option.
I have a cream Leopold FC750 and this would literally look like the beach on my board.
Offline oldcat
  • 65% is Life
« Reply #71 on: Sat, 23 May 2020, 16:20:34 »
ePBT should be better in PBT, no?
Offline Mcnos
    • GMK Fuyu
« Reply #72 on: Sat, 23 May 2020, 18:08:23 »
KAT isn't glossy though in the least.
Also ePBT isn't accepting any reverse dye sub at the moment as far as I'm concerned. This set is leaning towards GMK anyhow
Offline Zeelobby
« Reply #73 on: Sat, 23 May 2020, 18:27:30 »
Yeah. Neither KAM nor KAT has to be glossy. Pretty sure it was choice made for that set. KAM Wraith is not going to be glossy and almost all other KAT sets aren't planned to be either.
Offline Zeelobby
« Reply #74 on: Sat, 23 May 2020, 18:28:29 »
Any chance of Infinikey PBT? Between sanctuary rebirth and bred delivering now and some samples of WoB, it looks like they've got reverse dyesub down.
Offline Zeelobby
« Reply #75 on: Sat, 23 May 2020, 18:32:47 »
Not that I have anything against GMK, i just can't join any more GBs that won't show up until 2022
Offline Mcnos
    • GMK Fuyu
« Reply #76 on: Sat, 23 May 2020, 18:51:22 »
There's a chance.
Offline Mcnos
    • GMK Fuyu
« Reply #77 on: Sat, 23 May 2020, 19:14:44 »
Offline CrazyAssMonkey
« Reply #78 on: Sat, 23 May 2020, 20:07:03 »
ne 660 render avail?
Offline steezkeez
« Reply #79 on: Sat, 23 May 2020, 21:24:26 »
Offline SlurmsMacKenzie
« Reply #80 on: Sat, 23 May 2020, 21:29:18 »
That mono kit is great.  After seeing the renders, I personally like GMK over KAT with the gradient set.
  • MATRIXの日常
« Reply #81 on: Sat, 23 May 2020, 21:46:57 »
This is it!!!
« Reply #82 on: Sat, 23 May 2020, 21:52:46 »
gmk in mono
kat in gradient
Offline Mcnos
    • GMK Fuyu
« Reply #83 on: Sat, 23 May 2020, 22:54:35 »
« Reply #84 on: Sat, 23 May 2020, 23:00:05 »
Offline kiwoli
« Reply #85 on: Sat, 23 May 2020, 23:04:08 »
gmk in mono
kat in gradient
Heart says yes, wallet says no.
On a serious note, I'll probably be in with either profile regardless. Additional mono kit also a good call.
Now the question is whether to offer this as a mono kit with gradient add ons or the other way around.
Offline Mcnos
    • GMK Fuyu
« Reply #86 on: Sun, 24 May 2020, 00:35:18 »
gmk in mono
kat in gradient
For sure, gradient base with mono add-on.
« Reply #87 on: Sun, 24 May 2020, 00:43:26 »
man thats awesome..
Offline CaptRiskyBiscuits
Re: [IC] Tidal (new renders)
« Reply #88 on: Thu, 28 May 2020, 01:16:51 »
I'm definitely interested if cherry profile!
Offline PheonixStarr
« Reply #89 on: Thu, 28 May 2020, 02:05:47 »
I don't usually like gradient sets, but this is kind of sexy.
Offline dibkib
« Reply #90 on: Tue, 16 June 2020, 08:20:06 »
I somehow missed this IC. I really like both the gradient and the option to go mono, and would prefer a Cherry profile (GMK or other, not picky there)
Offline Mcnos
    • GMK Fuyu
Re: [IC] Infinikey Tidal (Kit Reveal)
« Reply #91 on: Wed, 17 June 2020, 00:03:14 »
Please review the kits and let me know of any suggestions you may have, some stuff may have slipped past my eyes but I've scanned it over a several times to fulfill most layouts.
Base
Add-on
Mono
Oh, and we are rolling with Infinikey - I'm sure a lot of people can appreciate the cost factor as well as the cherry profile.
« Last Edit: Wed, 17 June 2020, 00:07:21 by Mcnos »
Offline kiwoli
« Reply #92 on: Wed, 17 June 2020, 00:23:15 »
I'm ready.
I'm actually interested to know exact colours though.
Offline Mcnos
    • GMK Fuyu
« Reply #93 on: Wed, 17 June 2020, 00:30:16 »
I'm ready.
I won't announce that until a later date, perhaps when GB gets closer.
Offline bewareofpixels
« Reply #94 on: Wed, 17 June 2020, 01:20:53 »
This is gorgeous! Can't wait :)
40% Only.
Offline manaorme
« Reply #95 on: Wed, 17 June 2020, 04:22:01 »
Infinikey knows how to make reverse dye-sub legend.
Sa, Kat and Mt3 are high profile.
Gmk is high cost.
Infinikey has a reasonable price and supports various layouts.
I saw Infinikey Sanctuary Rebirth recently, and It looked really great.
Offline robotictomato
« Reply #96 on: Wed, 17 June 2020, 15:39:18 »
The kits look very good. I'm glad you decided to go with Infinikey as well!
Offline konstantin
  • Formerly constexpr
« Reply #97 on: Wed, 17 June 2020, 17:57:16 »
Base
Add-on
Mono
Kits look good for the most part! I would suggest changing R4 1.25u Menu to Fn, though, since there's no 1.25u Fn key anywhere in the set right now — a key that's regularly seen used on 60%, 65%, 75%, TKL and other keyboards. If Menu is something that you really feel is worth including, it should be in the add-on kit, but it also may not be necessary at all. Either way, Fn is more important.
Other than that, there's a duplicate set of darker blue 1u Ctrl and Alt keys: one pair in the base kit and one pair in the add-on kit. I think the one in the base kit is superfluous, as 1u LCtrl and LAlt would only be useful for 40% boards, if I'm not mistaken.
Finally, it'd be cool to see a R3 1.75u Function key added to the add-on kit. Mac users may like a R3 1.75u Command as well.
(Edit: Looks like there's a 1.75u Function in the mono kit, but not in base 🤔)
I'd also maybe move numpad 00 to the add-on kit, not sure.
« Last Edit: Wed, 17 June 2020, 18:00:14 by konstantin »
Offline Mcnos
    • GMK Fuyu
« Reply #98 on: Wed, 17 June 2020, 20:34:29 »
Ah yes, I see the duplicate ctrl/alt in the add-on kit. Thanks for pointing that out.
I'll be adding R3 1.75 Function to add-on
Replacing Menu for Fn and adding Menu to add-on
Base kit for the most part will stay the same
« Last Edit: Sat, 20 June 2020, 18:22:06 by Mcnos »
Offline depletedvespene
    • Keyboard-related resources.
« Reply #99 on: Sat, 20 June 2020, 17:24:51 »
Base
Add-on
- I'll say the same thing I say of all Infinikey-run sets so far: swap R3 #~ in the base kit with the R3 \| key in the add-on kit, and both kits will be cleaner for it.
- You have same-colored F13 keys in both base and add-on kits (I'd keep only the one in the add-on kit).
- An R4 1.25U Fn key (independent of the Menu key) would be a nice addition in either kit.
- You could replace the R1 white Esc key in the mono kit with an R3 white Esc (so there will be R2 and R3 white Esc keys in there, as the white R1 Esc key is already in the base kit).
