Author Topic: OTD The Cheat screw size?  (Read 1455 times)
Offline brohothepirate
« on: Thu, 14 May 2020, 14:42:11 »
Bought one that doesn't have a bottom screw. Looks like the thread isn't stripped but how do I find out what size the screw is? Not a hardware person at all.
Is the best approach simply to take out the other screws and replace with a full set of new, identical (to each other) screws?
Offline Maledicted
Re: OTD The Cheat screw size?
« Reply #1 on: Fri, 15 May 2020, 14:28:53 »
Do you have any screws that are most likely identical to the one you're missing? If you do, take it to your local hardware store. I like Fleet Farm and Ace Hardware (No idea if you've got those around). A good hardware store will usually have some sort of sizing tool you can try to screw a duplicate screw into until you determine the correct threading. With that new-found information, you can start digging through their inventory for a screw of the same threading and as close as you can get to the same length. Sometimes you've got to worry about the width of the recess it may be going into as well. I know with my IBM F107, I ended up having to use some hex cap machine screws I had picked up vs the stainless phillips pan head screws I would have preferred because the heads on the phillips screws were just a bit too wide.
Offline typo
« Reply #2 on: Fri, 15 May 2020, 16:53:34 »
Take out a other screw. Than go to an Ace. Only an Ace has this AFAIK. they have nuts you can screw into to find the size! Both metric and SAE! I am sure it is metric. Oops, exactly what 'Mal just said lol.
