Author Topic: Is There A Programmable Chicklet Matrix Keyboard With Extra Rows?  (Read 1432 times)
Offline DiscipleOfCeres
I'm looking at this keyboard:
https://cherryamericas.com/cherry-g86-63400.html
I don't think it's chicklet. It's rubber dome, and probably with more travel than chicklet keyboards. Why on earth do I like chicklets? Just a practical consideration, I'm working with the idea of sliding fingers across multiple keys. And I'm looking for extra keys to experiment with using transitions of the hands (one idea is to toggle sub-layouts (have one area to shift to one layout or another), another swapping right-left, it might be hard, but it might be fun too).
I don't need to use it for gaming. But if it permitted up to 6 arbitrary keys simultaneously, that would be another fun experiment (chording/stenography-inspired layouts).
Also, if anybody has seen a hexagonal keyboard (like a hexagonal D&D gaming mat), I'm interested in learning more.
Offline dusan
Re: Is There A Programmable Chicklet Matrix Keyboard With Extra Rows?
« Reply #1 on: Fri, 15 May 2020, 05:05:28 »
This is a POS keyboard. Keycaps are flat, but not thin. They don't look like chiclets.
If you're in EU/UK you can buy one similar to this, with Cherry MX (black) switches, from Active Key's online shop or one of its authorized dealers (https://www.activekey.de/). Ask one of the dealers if you're interested in other brands/models.
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
